| | | Forums66 Topics128,288 Posts1,058,579 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I have put a 235 in my 49 1/2 ton an having trouble with the clutch. It is a 10 inch in there now but I have a new 9 inch clutch, pressure plate. If the bolt pattern is the same will the 9 inch stuff work as well? Still using original starter, bell housing, an clutch fork. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Either size clutch assembly would probably work fine in normal driving. Of course, you can only use an assembly that will bolt-up to the flywheel.
Be sure to use a clutch assembly with matching pressure-plate and release bearing (there are two lengths of release bearings, each matching a different "height" pressure plate).
| | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Thanks for the info will try it an see | | |
