| | | Forums66 Topics128,212 Posts1,057,463 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | howdy Paint & Body Shop people, I have this hubcap here: hubcap in question(link to photo) ... and I've had a notion to paint the groove of the Chevy Bowtie a shade of the old 60's Chevy orange. It is a stamped metal, material... ... so my question is about, the preparation and paint. This is my daily driver, so it is going to get dirty, etc.. Suggestions? Just an idea I am playing with. Thanks for any information. -W | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | use pinstripe or model paint, same as for the color touches on emblems, no prep except good cleaning, expect to need redoing it over time, those look like the stamped stainless shell type
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Like Bill suggests, or you can let your BC or single stage paint sit out for a few hours or until it thickens up some and then use it.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | My caps are striped, there was no additional prep, just make sure they're well cleaned.
Just use striping paint and a fine brush. If it's well done it shouldn't need redoing until many years later. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | If you can get accurate dimensions your local sign shop could make those for you out of colored vinyl. Clean the hubcaps, stick the vinyl in place... | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I've done some emblems in Chevy orange. (57 Fender Emblems & hood emblems, chrome and orange) Lot of masking. Do you intend on masking or hand brush? I, myself, could not do a good job on those by hand. I had several problems tying that on emblems. I took a million pics to do a Tech Tip but did not really feel qualified to give advice. Just my lessons learned.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Woog, I use One-Shot striping/sign painter's enamel, it will level out using a quality brush, no masking on that simply dip a cotton swab in thinner/reducer/acetone to remove any overpaint. | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Thanks for the suggestions everyone.
-W | | |
