1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | I just tried a carter w-2 carb on my 235 1949 and it leaks bad out the shaft area. so for the heck of it i put one off a I.H. bd220 i have.bolt pattern matched. it seems to run with it on the stand.havent tried in truck yet. anyone used one of these holleys off a I.H.is it ok to use. thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You may want to look at the linkage connections and also check into the metering rod sizes to see if they are close to the original carb for your truck. I think you mean a "W-1". | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A carburetor is simply a chunk of metal with a hole in the middle for air to pass thru with another hole plumbed into the side from a source for fuel. If you can get it to fit and get it hooked up to the controls, fuel and vacuum lines then sure it will probably run. How well it will run is another matter and if the throttle shaft is badly worn it will still run the engine but not very smoothly. Is it ok to use? All depends on what you're expectations are.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Denny, That's the BEST description of "applied carburetor science" I have ever seen in print! My hat is off to you!
Les | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Don't forget, I've got one of each bolt pattern carb you can try on your engine if you like. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Two stovebolters in a community 5003 people? Are there a lot of old vehicles up in Homer? | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Not a great amount of old vehicles, I know of several. There is at least one more bolter that I'm friends with, Homeradam. Now that I think of it I know of at least 2 early 40's IH pickups and another 46 chevy pickup, my neighbor has a FULLY restored AD that is beautiful. I know of another AD that was done by patricks. Dave
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Went to the street view on Google maps and din't see any of your vehicles out in the yard, ya must live out of town Homer. Must be a lot of tourist traffic up there with all the museums I saw.
RW, I'd look up the other guys and see If I couldn't find a carb designed to fit your truck.
DG
| | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | Being a bit of a carter guy I'll pass on that the carters were very, very specific about the carburetors they made for your engine. Try to find an original designed for that engine and then rebuild it - get the carter spec sheet and follow it. I had no idea carter was so precise until I started to buy up old inventories - they were manic about them. What IH carb, a tillotson or zenith? is that what they used? I've always had deep respect for the IH carbs but never did one from late 40's
A shop is where you wash your hands before you pee.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | As long as the throttle arm has the correct orientation to work with the throttle linkage, and the carb isn't worn out, shouldn't be an issue. Rebuild kits, other than floats, are easy to find, and they take the same jets as the 2 and 4 barrel modern Holley carbs. I'm running a pair of them on mine, sourced them from a later 240 Black Diamond. I did have to modify the linkage to make them work, as the IH intakes are on the opposite side of the engine from Chevrolet.
Bill Burmeister | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | denny that google earth map if its witin about 2 1/2 years should show my truck as it hasnt moved in that time!!! wife giving me a little more time before she plants trees/shrubbs around it. the prob I was having was finding a carb that had the tag on it. dave is offering to let me try a couple he has. got a newer 59 engine see how the new ring job goes.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, that's what'ca need rw, a buddy close by who you can swap ideas with. Sounds like there are a few of you right there in Homer. When you're working with parts that are more than half a century old such as a carburetor, you can bet the farm that it's been rebuilt at least once probably several times. A lot of guys neglect to put the tags back on, I suppose the train of thought is that once they rebuild it, there won't be need to do it again.
I'm pretty sure Google earth is up dated more often then that so you probably are on stage. Of course, I didn't have a chance to canvas the whole town. I was thinking McCabe and Mrs. Miller, instead you guys got a sprawling metropolis up there. DG
