| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | GM Panel Truck Assembly line Photo, Norwood, Ohio PHOTO, Negative of the same photo. Photo came from this Web Site where there is a photo slide of the plant, which ran from 1923-1987. The website is The official site of the first of its kind Book "Echoes Of Norwood"Listen to the 27 minute Interview with the Author of the book on Hemmings Motor News Radio! You learn where the phrase "A Fly in the Ointment" came from. The workers were treated pretty harshly. History of Norwood Assembly Plant | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's 1 or 2 similar panel assembly photos over at oldGMCtrucks .... and there's a bunch of 59 assembly line pics here mostly cars, but some good engine pics Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Trivia quiz: I do not think you can ID the year in the Norwood photo posted by Jorb, but, what were the possible range of years?
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Tough one, obviously A-D. I'm looking at the little hole in the left rear door post for the wire conduit to power the tail-stop lamp. I remember hearing that some years used contact points instead. My '53 has that conduit...I might be on the wrong track though. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Trivia quiz: I do not think you can ID the year in the Norwood photo posted by Jorb, but, what were the possible range of years? pre-1951 panel | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | George,
I thought you'd check in on this. Explain your answer, for the benefit of others. I think I can get it down to a smaller range of years (maybe one/two years, if you are correct).
Also, did you post information of different wood strips in the panel side walls over A-D years?
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The planks were changed in 1950 to plywood, the center hole in the sill for the spare tire was pre-1951 and the elongated hole for the rear light was changed in 1951.
I am sure we hashed out the plank issue several times………….g | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I will say 1950 panel truck. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Not sure on year, but the closer Panel truck is a 1 ton and the further one is a 1/2 ton. Did all AD 47-55 1st 1 ton Panel trucks have a one piece plywood floor? Didn't the 1950 floor design change, only effect 1/2 ton panel? Could a Panel truck be ordered with a Clam shell end gate? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I thought we had discussed this FACTORY PHOTO before. After a closer look, It's a step or two after the photo jorb gave us and looks to be a different assembly line with different step in assembly. This one has the cowl installed before the side panels, jobs has the side panels installed first, both have a one ton and half ton in the same position………..g Could a Panel truck be ordered with a Clam shell end gate? Only the suburban and canopy express came with clam shell tailgates. The suburban had them 1947/55, barn doors were not available 1947/49 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think they are different assembly lines (jorb vs GMONIZ links).
The plywood floor with 5 metal skid strips was introduced in 1950.
I think that some people see the driver's side cowl-vent, making it pre-1951.
So, if the above observations are correct: 1950?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Could a Panel truck be ordered with a Clam shell end gate? Only the suburban and canopy express came with clam shell tailgates. The suburban had them 1947/55, barn doors were not available 1947/49 Rear doors ("panel" doors) on Suburbans were introduced in 1950. Suburbans had only end-gates/tail-gates from 47-49. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I cannot tell from either photo whether or not these panels have plywood floors. They both have five metal strips. One photo shows an adhesive or caulking on the passengers edge, the other does not. Since one photo (SUBURBAN) shows a cowl which some (me) believe that there are louvers on the left side making it pre-1951 and the other does not have the cowl, I cannot discern the year. If this was a suburban assembly line, I would be able to see other differences that would help determine the year. ASSEMBLY PLANT PHOTO #1 - NO COWL ASSEMBLY PLANT PHOTO #2 - WITH COWL SUBURBAN ASSEMBLY PLANT PHOTO WITH COWL This one is a 1950 or newer, my guess is 1950. | | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | This is a great thread. I have been a long-time panel fan (since 1968), and I need to learn these details, history and background.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Extremely cool pictures there. I know nothing about plywood in the auto industry, and the only observation I have is the cutout size around the rear wheel well produces a very narrow piece on the deck. I'd be leaning towards that piece being solid wood material for strength on the exposed edge. Then one could argue if the outsides are solid why use plywood in the middle? Don't know just saying from my perspective. At any rate, I love seeing early assembly line pictures. We need to find an 80 year old GM truck assembly line worker that knows how to get out of the rocking chair and get online here. Steve
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | sstock, from all my study, and reading here, they were either all boards or all plywood. No mixing of the two. Despite the cut outs for fenders my 52 panel is all plywood (I think 54" wide) and yes, it had skid strips to help delivery folks slide their stuff in and out of the panel..... but no telling what someone did to them over the years once they left the factory.
From pics and the post above I'd also vote 1950.
Don't want to muddy the water here and start another thread but its my understanding that for my year '52 the body and plywood was "one piece" when it was set on the frame...and I believe it after tearing mine all apart and seeing how it was. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | In 1950 the panel trucks' floors changed to plywood with 5 metal strips over the plywood.
Prior to 1950, panel trucks had 13 boards and twelve strips.
You can tell from the photo that the panels had 5 strips (you can then assume there was plywood under those strips).
47-55 Suburbans had plywood floors.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | If I'm reading this right. Looks like the rear body sills were different for a specific year, tonnage and whether the truck was ordered with Clam Shell doors or Barn doors. Master Parts Catalog 1929-1954 Group Number 17.166 PANEL, Body Lower Rear, pages 776 and 777 Wonder what the differences were? Asterisk note: When used on Sub. w/end gate hinge cutouts have to be made, cross sill reinforcement must also be retained. What ever that means. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the clamshell lower panel would need to have provision for the lower gate hinges, and as per the note, need reinforcing to support that additional weight and for Chips "its my understanding that for my year '52 the body and plywood was "one piece" when it was set on the frame" .... I had a picture I can't find of a TF panel body, complete w/ doors and front clip being 'dropped' onto a completed chassis, that's the way all years of panel and burbs were done, notice in the pics linked above that the bodies are being assembled on support jigs ...  Bill | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | red58, Something like this. Panel body, complete w/ doors being 'dropped' onto completed chassis. PHOTO Minus the front clip. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, that's the way they were done, pickups and cars as wellBill | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | This is something else I didn't know. There is a difference between the 47-53 and the 54 Panel, Suburban Top Assembly (roof) Group number 17.060 Top Assembly I thought the 47-55 1st series Panels and Suburbans roofs were all the same. Except for the longer length on the 1 ton. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The roof fits over the windshield, which changed for 54/55 (one-piece curved vs earlier two-piece flat.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim, the difference in the listing shows the 'burb roof for all years being different than the "single unit" [panel] for the same years ... must have to do with variation for the side windows?
Bill | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I think the only variation that is different between the panel and suburban roof (other than the windshield change in 1954) is the rear header, the suburban has two choices of door styles and the rear header has both mounts on the suburban. IMO | | |
