4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
#1008895 02/21/2014 10:00 PM
Hi list
I was just on the phone with Coker Tire trying to order a set of tires and tubes when the question arose of what size valve stem I have. Unfortunately I am still a looong way from home so I can't measure it but I was hoping one of you could help. The wheels are 4.00 x 16, lets say they came off a 1950 Chevrolet 3100 (just guessing). Can someone kindly tell me what the hole diameter in the rim is for the valve stem? The choices are 3/8 or 1/2. Thanks!
1955 First Series 3100
I have one extra wheel which is unmounted and is 4.00 x 16, six lug. I measured the hole and it is 5/8. This wheel is for both my '42 and '51, so I assume it is the same as yours. It had a tubeless type valve stem in it which I removed to measure. Possibly someone drilled it out? It is definitely 5/8, not 3/8 or 1/2. Maybe someone else can offer advice.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Valve stems got smaller in the mid 50's. 5/8" was standard for the large stem and the small that became popular in the mid 50's measured a little less than 1/2". I have never heard of a 3/8" valve stem.
Thanks for the responses, I did clarify with Coker, they are selling me a TR11 valve stem with a grommet so it will be indistinguishable from the TR15 (which is the 5/8" one). The gromet idea sounds hokey to me, does anyone have experience with this set up?
Joe
When the smaller stems became popular, it was common to use a grommet. It cut down on our tube inventory. We didn't have to stock both stem sizes. We would just give the customer an adapter if he had the 5/8" hole. There is nothing wrong with using the grommets. We weren't concerned on how they looked in those days. 5/8" stems that you can vulcanize on can still be bought. We used to vulcanize stems on all the time if someone either hit the stem with a tire hammer or if someone mounted a tube off center and it rubbed a hole in the stem. I wouldn't recommend cutting a small stem off in order to vulcanize a 5/8" stem on. I'm not sure how well today's tubes vulcanize.
