0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Boy-o-boy, "Servicing the Truck Cab" is a win for me. I'll be using that real soon. Thanks, Brad!
Drew
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Thanks again Brad, I also really like the "Servicing the Truck Cab". Lots of information. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes I must admit that is one of my favorites. | | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Great stuff that "servicing the truck cab" is! Yes indeed! I wish there was something like that for fitting an AD hood. I cant wait to fit mine properly, it looks bad.
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Great stuff that "servicing the truck cab" is! Yes indeed! I wish there was something like that for fitting an AD hood. I cant wait to fit mine properly, it looks bad. Marco, have you checked/adjusted the front and rear cab mounts for the specified gaps between the bottom of the cab and the frame. This, in addition to the proper spacing at the bottom of the radiator bracket will likely help you getting your hood to line up. The Factory Repair Manual will walk you though these adjustments. Unfortunately it doesn't explain that these cab adjustments are crucial to getting the hood adjusted properly. The fender bolts also need to be loosened and lowered before you start. Carl
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
