| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | On my 49 3100, the outside door handles droop down after closed. To correct this do I need to replace the door handles or is there a replacement spring that will fix this. If a spring replacement where is the spring replaced and are there any pictures or diagrams available? | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | You may do a search or tech tips on this site. I have seen this discussed before, but cannot remember the remedy. Someone had a way to fix this.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I've not tried this, but Classic Parts has a spring that is supposed to help with this condition: http://www.classicparts.com/1947-51-Door-Latch-Spring/productinfo/18-575/#.UwYzyYUz0UY I'm not aware of pictures or diagrams on this parts - they dont' seem to be designed for servicing. Last time mine needed work, I took it apart and used an old one for reference. Good luck & have fun working on your truck. Bill
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | |
