8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible),
100
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 16 | Does anyone have a theory how to obtain a key for the electroloc ignition system on my "36 pickup? I have all the working parts but a key. My locksmith is stonewalled. The cylinder is in the locked position so it can't be removed from the housing, there are NO numbers anywhere to give a hint as to a code and etching attempts to produce a key by trial and error have proved frustrating and fruitless!!
I'll take any direction anyone has to offer.........Thanks - again!! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | would this work... click here do you have a pix of it.. is it a stock 36 pick-up.. I would think that a good locksmith could come out and get it going...it would be the same as taking the ignition to him.. I may have miss read, you do have it out already,, if so a good lock smith should be able to fix it. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joker, Those neat E-bay keys are blanks! You get an E for effort though. Stuart | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | how about this site........go down to about 11 to the key number h1098la click here if you find one, you better buy 2 and hide one says they are in stock... hope this works, I still think a good smith could fix you up if they had a blank.. the hard part seems to finding the blank, ... you now have sites for both.. I lost my key for my international, took the whole deal out to the locksmith,, bingo,, new key.. no problem Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2006 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 16 | Sorry gentlemen........I was not clear!! I have a blank key but no code to use for cutting it so it will trip the switch and send electricity to the starter. It's the code I need help with.. There are no numbers on the cylinder or it's housing. I'ts an original set up.
Sorry for causing confusion. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure what type of lock is in a 36, but maybe print out this page and the 2 following pages and ..... take them to a better locksmith - any good locksmith should be able to figure out how to make a key for any lock ..... should be able to drill something to remove the cylinder as well Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | buy this book looks like this might work Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 |
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might want to update that old truck doc.. wow  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's been a couple of years since I had mine out so I'm not sure if the key has to be in the run position or not to be removed but there is a hole in the face of the ignition switch that you can stick a paper clip into to release the cylinder from the housing. Once the cylinder is out a locksmith can make it work on any code. If the cylinder isn't removable in the off position they are simple locks for a trained locksmith to pick & turn to the run position. If there isn't a locksmith in your area that can pick locks you can try contacting a repo outfit in your area. Most have folks trained in picking locks and could most likely get your ignition into the run position where the cylinder could be removed. Good luck.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Tiny:
On my '46, the key does have to be in the run position to remove the cylinder.
Footbiz:
I also suggest taking it to a different locksmith for a second opinion. If all else fails, pull it and get a new one. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | On my 53 the PO took a key and filed off the ridges. It is smooth across the top and turns the tumbler. You may want to try this if you have an old key.
I plan to take the tumbler out of my 53 and have it keyed like my 55 2nd. I will do the same with the door lock. Probably put a door lock on the drivers door, too. I did that on the 55.
Just a suggestion.
Dennis -there is nothing stronger than the heart of a volunteer-
