6 members (stlcardinalsguy, TexasJim50, Woodcmiami, klhansen, Hanks custodian, Wally / Montana), 65 guests, and 2 robots.
Topics128,059
Posts1,055,820
#100853 05/23/2007 10:40 PM
Does anyone have a theory how to obtain a key for the electroloc ignition system on my "36 pickup? I have all the working parts but a key. My locksmith is stonewalled. The cylinder is in the locked position so it can't be removed from the housing, there are NO numbers anywhere to give a hint as to a code and etching attempts to produce a key by trial and error have proved frustrating and fruitless!!
I'll take any direction anyone has to offer.........Thanks - again!!
#100854 05/23/2007 11:47 PM
would this work...
click here
do you have a pix of it.. is it a stock 36 pick-up.. I would think that a good locksmith could come out and get it going...it would be the same as taking the ignition to him.. I may have miss read, you do have it out already,, if so a good lock smith should be able to fix it.
Redryder pix
My Hotrod
#100855 05/24/2007 12:01 AM
Joker,
Those neat E-bay keys are blanks! You get an E for effort though. smile
Stuart
#100856 05/24/2007 12:06 AM
how about this site........go down to about 11 to the key number h1098la
click here
if you find one, you better buy 2 and hide one
says they are in stock... hope this works, I still think a good smith could fix you up if they had a blank.. the hard part seems to finding the blank, ... you now have sites for both..
I lost my key for my international, took the whole deal out to the locksmith,, bingo,, new key.. no problem
Redryder pix
My Hotrod
#100857 05/24/2007 12:15 AM
Sorry gentlemen........I was not clear!! I have a blank key but no code to use for cutting it so it will trip the switch and send electricity to the starter. It's the code I need help with.. There are no numbers on the cylinder or it's housing. I'ts an original set up.
Sorry for causing confusion.
#100858 05/24/2007 12:35 AM
not sure what type of lock is in a 36, but maybe print out this page and the 2 following pages and ..... take them to a better locksmith - any good locksmith should be able to figure out how to make a key for any lock ..... should be able to drill something to remove the cylinder as well
#100859 05/24/2007 12:59 AM
buy this book looks like this might work
Redryder pix
My Hotrod
#100860 05/24/2007 1:10 AM
You mean a screw driver wont work? What about a pocket knife? grin grin grin grin grin grin
Chey
LOST1953
My favorite color is CHROME
The ugliest trucks are driven by the prettiest girls wink
I dont suffer from insanity, I enjoy it!
O Lord, WHY did I buy another "Thing"? (again??)
1953 Chevy 3800 1-ton Gallery
More photos at MSN
#100861 05/24/2007 1:17 AM
you might want to update that old truck doc..
wow grin wink
Redryder pix
My Hotrod
#100862 05/24/2007 2:46 PM
Ex Hall Monitor
Ex Hall Monitor
It's been a couple of years since I had mine out so I'm not sure if the key has to be in the run position or not to be removed but there is a hole in the face of the ignition switch that you can stick a paper clip into to release the cylinder from the housing. Once the cylinder is out a locksmith can make it work on any code.
If the cylinder isn't removable in the off position they are simple locks for a trained locksmith to pick & turn to the run position. If there isn't a locksmith in your area that can pick locks you can try contacting a repo outfit in your area. Most have folks trained in picking locks and could most likely get your ignition into the run position where the cylinder could be removed. Good luck.
#100863 05/24/2007 6:04 PM
Tiny:
On my '46, the key does have to be in the run position to remove the cylinder.
Footbiz:
I also suggest taking it to a different locksmith for a second opinion. If all else fails, pull it and get a new one.
#100864 05/25/2007 1:08 PM
On my 53 the PO took a key and filed off the ridges. It is smooth across the top and turns the tumbler. You may want to try this if you have an old key.
I plan to take the tumbler out of my 53 and have it keyed like my 55 2nd. I will do the same with the door lock. Probably put a door lock on the drivers door, too. I did that on the 55.
Just a suggestion.
Dennis
