3 members (Bill Hanlon, Lightholder's Dad, baldeagle), 38 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#1008138 02/18/2014 5:08 PM
Has anyone plans please to make up an alternator bracket to replace my dynamo on my 235 .
Phil
wc54 #1008151 02/18/2014 6:06 PM
Brackets are readily available from common vendors. Search or look on site for list of vendors.
yes i know , but was trying to make one here in the UK
phil
wc54 #1008353 02/19/2014 2:20 PM
Go on EBay and search. Looking at pics and measuring off your block and alternator would likely provide the info and style you want. Some are very simplistic.
Drew
wc54 #1008388 02/19/2014 4:37 PM
Had mine made at a local machine shop in less than an hour for about $20.00.
RdsLessTaken/Don
Alternator Bracket:
http://s1291.photobucket.com/user/R...20Boards/IMG_4516sm_zps9f95c14e.jpg.html
Library:
http://s1291.photobucket.com/user/RdLessTaken/library/
wc54 #1008390 02/19/2014 4:47 PM
Just use the original bracket with a long bolt, and a piece of pipe or thickwall tubing as a spacer. A bit of measuring and a hacksaw, and a few flat washers if necessary should get the job done. I have used "all-thread" rod and flat washers to mount an alternator, but a spacer to hide the threads looks a little more professional.
wc54 #1008557 02/20/2014 12:06 PM
thanks very much
|PHil
wc54 #1008882 02/21/2014 9:32 PM
Thanks,HRL!! Always GOOD advice,Jerry!!
Mo' Tater
