1 members (MickeyP), 122 guests, and 2 robots.
Topics128,088
Posts1,056,114
Members48,434
#1007882 02/17/2014 6:15 PM
Replacing the u-joints on my 59' 3100 and the new one was loose in the yoke one one side. Also, the other side looks like someone took a hammer to it and broke it: Pic of Yoke
I've searched my normal replacement part sites but was unable to locate a brand new yoke. Any suggestions for me?
-Troy
H Online: Content
Yes, you need a new yoke, and it's possible the only source will be a salvage yard. You might try a shop that specializes in rebuilding driveshafts, as they will have sources the average parts store won't know about. It's also possible that one might be listed on Ebay, but be absolutely sure the diameter, length, spline count, etc. is correct before ordering one from somewhere before doing a side-by-side comparison. Fortunately, there's a pretty good bit of interchangeability on slip yokes, sometimes even crossing over car lines- - - -GM, Ford, MOPAR, etc.
I'd say you need one, but I don't think they're in the system anymore [check NAPA?] so you're looking for good used - wrecking yard, parts wanted here, or e-bay .... any up to mid-60's when the spline count changed should do
Find a big truck shop in your area that does driveline work. They should be able to get you a yoke.
' Offline
I agree that you need a new yoke.
Any chance that you can supply a GM
part # of the yoke you need ?
I'll see if I can hunt one down GM NOS.
Of course you can always do the
scrap yard thing.
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
I always run an OEM part number on an eBay search. Lots of time people have something listed by p/n and have no clue as to what it fits. I have found a lot of hard to find parts like that.
scrap yard thing.
George
in
New Jersey
I assume it will be on the yoke itself? I'll take a look tomorrow.
-Troy
Any number you find on the yoke will probably be a casting number. The best would be to find the part number. I have all GMC and don't know much about Chev. It will probably be the same as a GMC and Chev and GMC use the same part numbers. However, GMC and Chev have different group numbers.
master parts manual here, near the bottom > "55-57 1/2T (except hvy dty & 4 spd)", 1&5/16 dia bore, should be the same as 59, p/n 3707059
H Online: Content
There are dozens of brand new yokes on Ebay right now- - - -just need to figure out which one will fit!
' Offline
Greetings from New Jersey ,
Found ( 1 ) GM NOS Yoke - GM # 3707059
ebay seller: bobalindalu
ebay item # : 190901159953
photo @ photobucket
http://i669.photobucket.com/albums/vv57/glp0329/YOKE/GM3707059_GM_NOS__zpscc25dd92.jpg
http://www.ebay.com/itm/NOS-GM-1964...ries&hash=item2c72988811&vxp=mtr
Dan's Obsolete GM Parts
in Chinook, Montana
also has ( 1 ) - GM # 3707059
phone: 406 - 357 - 2615
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
