7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1007213 02/14/2014 9:06 PM
Boy we're having fun now! The scraper seals hang up on the window frame, anyone have the same problem and a possible solution? The window won't go down past the contact point with the scraper at the front of the window. Thanks Scott
Scott,
You may have to bend the channel on either the door or the door panel to adjust the clearance for the wiper seal. Did you crimp the metal so that it holds the seal?
Paul
Lots more pictures
Yes it is crimped in place, I have tried getting it as vertical as possible and it goes down fine without curling down with the window until it comes in contact with the metal frame, which naturally hapens first towards the front due to the slope of the window. If it ran the full length of the opening this would not happen but as you know the crimp groove dosen't run that far and there is nothing to attatch it to beyond it. Scott
Scott,
I am not certain what to recommend from your description. Are you sure that there is no binding in other parts such as the window regulator and or track? Have you greased the lower window track and regulator gears yet? I found that a little grease in the right places made the windows function considerably better.
Paul
Lots more pictures
No evrything works great until the perimiter frame around the glass contacts the scraper seal. I don't see how this ever could haved worked, not sure what I am missing. Scott
My scraper seal extends past the end of the crimp groove at least 1/2" on each end. I have no problems with binding or it impeding the motion of the window. I think you have to have a good look at yours to see what's binding, this isn't "normal operation".
My 46 GMC on Photobucket
With some help from Paul WNC we may have discovered that the scraper from Steele that I got may be the wrong dimension(too wide). Thanks Scott
My doors have both the rubber and felt wiper. I can measure if you need it.
After days of fooling around and trimming them I have reduced them to 1/8" or less (not counting the round part that fits into the crimp) And the leading edge still tries to grab at the front when the frame contacts it, but it works. Thanks,Scott
I am having the same issue with mine on a 1940 truck.
Do you still have the pictures of your scrapers?
You mentioned a felt, what is that?
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
[/[b]b]Don’t know if this will help with the discussion, but in working this stage on my ‘46 Chevy 1/2 ton I had the same problem. It was discovered there was in fact a difference between the products sold by Steele and Jim Carter’s. The Steele sweeps were wider diameter than those sold by Carter’s. A photo is attached showing the difference discovered. The Carter’s product was ultimately used. This experience was about 4 years ago, so their products might be different now. PLEASE SEE EDIT BELOW
EDIT on 12/12/2022: In helping figure this out and doing more digging and cross checking this is what I found. The Steele product was used on the outside channel and the Jim Carter product on the inside. Using all of one product or the other led to either to tight a fit to allow the window cranks to operate as needed, in one case, Steel. In the other the rubber was too narrow and didn’t “sweep” the window at all because of it didn’t sufficiently fit against the glass.
((A side note: A similar issue was experienced with the rubber cowel vent gasket. But, In that case the Steele gasket fit better than the Carter’
Can you send a picture as to how it looks from the end installed?
Mike
Maybe like this?
