1 members (Otto Skorzeny), 105 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#1008180 02/18/2014 9:00 PM
i was talking to a guy that put
a cast iron trans in his surb.
a cast iron trans from 1953-1954
chevy car he said it fit ,no modifacation
to drive shaft.any one else done
this trans.
Are you talking about an automatic or manual transmission? What engine are you working with?
i am running a 235 6cyl.
i am looking for cast iron auto.
1953-1954 chevy car
I've thought about that conversion myself. I've been told the cross member would need to be removed or modified where the clutch housing mounts are now. You'd probably have to change to side mounts on the 235 engine and possible fabricate or modify the rear mount for the automatic.... As far as the rest yes the torque tube is the same length in the 1/2 ton pickup and the car.
You'd probably also want to change the ring and pinion to a 3.55 ratio over your 3.90 or 4.10....
