1 members (TUTS 59),
55
Mod | | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | Has anyone plans please to make up an alternator bracket to replace my dynamo on my 235 . Thanks
Phil | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Brackets are readily available from common vendors. Search or look on site for list of vendors. | | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | yes i know , but was trying to make one here in the UK
Thanks phil
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Go on EBay and search. Looking at pics and measuring off your block and alternator would likely provide the info and style you want. Some are very simplistic.
Drew
| | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Just use the original bracket with a long bolt, and a piece of pipe or thickwall tubing as a spacer. A bit of measuring and a hacksaw, and a few flat washers if necessary should get the job done. I have used "all-thread" rod and flat washers to mount an alternator, but a spacer to hide the threads looks a little more professional. Jerry
| | | | | Joined: Dec 2012 Posts: 28 New Guy | | New Guy Joined: Dec 2012 Posts: 28 | | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,HRL!! Always GOOD advice,Jerry!! | | |
