1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 28 New Guy | | New Guy Joined: Jul 2011 Posts: 28 | Replacing the u-joints on my 59' 3100 and the new one was loose in the yoke one one side. Also, the other side looks like someone took a hammer to it and broke it: Pic of Yoke I've searched my normal replacement part sites but was unable to locate a brand new yoke. Any suggestions for me?
-Troy
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Yes, you need a new yoke, and it's possible the only source will be a salvage yard. You might try a shop that specializes in rebuilding driveshafts, as they will have sources the average parts store won't know about. It's also possible that one might be listed on Ebay, but be absolutely sure the diameter, length, spline count, etc. is correct before ordering one from somewhere before doing a side-by-side comparison. Fortunately, there's a pretty good bit of interchangeability on slip yokes, sometimes even crossing over car lines- - - -GM, Ford, MOPAR, etc. Jerry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd say you need one, but I don't think they're in the system anymore [check NAPA?] so you're looking for good used - wrecking yard, parts wanted here, or e-bay .... any up to mid-60's when the spline count changed should do
Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Find a big truck shop in your area that does driveline work. They should be able to get you a yoke. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | I agree that you need a new yoke. Any chance that you can supply a GM part # of the yoke you need ? I'll see if I can hunt one down GM NOS. Of course you can always do the scrap yard thing.
George in New Jersey | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I always run an OEM part number on an eBay search. Lots of time people have something listed by p/n and have no clue as to what it fits. I have found a lot of hard to find parts like that. | | | | | Joined: Jul 2011 Posts: 28 New Guy | | New Guy Joined: Jul 2011 Posts: 28 | I agree that you need a new yoke. Any chance that you can supply a GM part # of the yoke you need ? I'll see if I can hunt one down GM NOS. Of course you can always do the scrap yard thing.
George in New Jersey I assume it will be on the yoke itself? I'll take a look tomorrow.
-Troy
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Any number you find on the yoke will probably be a casting number. The best would be to find the part number. I have all GMC and don't know much about Chev. It will probably be the same as a GMC and Chev and GMC use the same part numbers. However, GMC and Chev have different group numbers. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | master parts manual here, near the bottom > "55-57 1/2T (except hvy dty & 4 spd)", 1&5/16 dia bore, should be the same as 59, p/n 3707059 Bill | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | There are dozens of brand new yokes on Ebay right now- - - -just need to figure out which one will fit! Jerry
