2 members (jmoore, Rusty Heaps), 91 guests, and 4 robots.
Topics128,264
Posts1,058,350
Members48,485
#1005154 02/07/2014 5:11 PM
Will a bench seat from a 67 - 72 c10, c20, c30 fit into a 62 c10? If so, can you tell the difference?
Thom Masterson
Bats62Chevy #1005162 02/07/2014 5:40 PM
The seat design changed in 1967, so I think they are NOT the same. I bought a seat from a 67 and they are different than the 1964-66 seats. I think all 1960-66 seats are the same.
http://s1278.photobucket.com/albums...amp;current=9493495_orig_zpsadd27406.jpg
Here's the seat I pulled from a 1967 C30. It was in such good condition that I suspect it may not be an original seat. It did NOT fold forward but the brackets aligned with the factory floor holes perfectly.
Bats62Chevy #1005206 02/07/2014 8:22 PM
So the 67 brackets match the 62 floor holes?
Other than the 67 seat not folding forwards, they look pretty much the same. Am I wrong?
Thom Masterson
Bats62Chevy #1005218 02/07/2014 9:38 PM
I can only say the bolt pattern on the seat in that photo,(if it really is a 67 seat) matched the floor on my 1965. I'm thinking other folks here can confirm that the 62 has the same seat brackets or not. If you look where the seat meets the back, you can see there is a piece of upholstery there. On a 64-66 there is going to be a visible hinge joint there.
Bats62Chevy #1005284 02/08/2014 3:11 AM
Socket Breaker
Socket Breaker
the 60-66 faq index at 67-72chevytrucks.com forum
Section 2D / Seats
check 'em all out, but the 'show us your seats' thread has lot of different styles in our 60-66 trucks.
seats thread at 60-66 area, chevytalk
have fun exploring.
-W
Bats62Chevy #1007873 02/17/2014 5:21 PM
The seat bolted into my '71 C10 is from a '63 C20. I removed both seats personally and bolted the current one in personally. It lined up perfectly. Now, that said, the brackets are different as far as height. The earlier brackets make the seat sit up a little higher in the later cab and the later seats will sit a little bit lower in the earlier cab.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
