6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#1007538 02/16/2014 2:12 AM
Hello,
Im pulling the steering column out of my pickup and am curious about the coupler/joint (with the rubber ring) for the lower end of steering shaft that connects to the steering gear box. First of all, the shop manual doesn't provide a name for the dang part (so I call it a coupler), so would love a name for it!
Secondly, where can I get a replacement for it? Don't see a part in LMC, would NAPA carry it?
Thirdly, how do I get it off of the shaft? I never got real aggressive with it since I don't know if I can get a new one or not.
Thanks!
lytlekj #1007635 02/16/2014 4:04 PM
Riding in the Passing Lane
It's commonly called a Rag-joint, but I believe coupler is the real name for it. You can get a repair kit for it at any parts store. It takes a little engenuity but works well. It seems LMC would have it or try Classic Parts. The complete assembly is pretty expensive at about $40-50. You need to remove the pinch bolt & unbolt it from the column flange to remove it.
1972 Chevy c10 Cheyenne Super
lytlekj #1007774 02/17/2014 2:31 AM
Rag joint or steering coupler, are the common names of the item you have described. We get our's from:
Lares Corp.
Dan Jones
800-334-5749
Application is important, but the spline count, input shaft shape & diameter, are the determining factors of which joint is needed. Commonly, the steering coupler rebuild kit is recommended.
lytlekj #1007776 02/17/2014 2:35 AM
As Tony mentions, Lares Corp. is well known in the restoration business.
My friend and local Mopar restoration specialist uses them almost exclusively.
lytlekj #1007802 02/17/2014 3:22 AM
Great help guys, thank you. Any trick to getting it off the shaft? it's seized on there pretty good.
Thanks again.
lytlekj #1007926 02/17/2014 9:46 PM
It shouldn't be that hard but you have to take the pinch bolt all the way out. The other end bolts to the flange on the strg. shaft.
