| | | Forums66 Topics128,156 Posts1,057,019 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 6 New Guy | | New Guy Joined: Jan 2014 Posts: 6 | Two Bolter responders asked me to make this a new post. Thanks for your responses and interest. By the way, I located and bought the original equipment rear shocks now have to figure how to bolt them on.
Re: rear axel [Re: retcon] c matamoros Moderated Registered: 29/01/14 Posts: 2 Loc: CA I have a '53 Chevy one ton pickup. Had it for 29 years. There are no shock absorbers on the rear and as I am getting older, the rigid bouncing around is no so much fun anymore. An old '47- '52 shop manual that i have says the 1 ton did not originally have shocks but it could be added on. I don't see any holes or brackets that I could fit shocks into. I have searched the internet until I am blind, called Chevy parts dealership, called many old Chevy parts houses - nothing. Do you know how I can get brackets and shocks on my old beast? Top Edit Reply Quote Quick Reply Quick Quote Notify #1002940 - 30/01/14 12:51 AM Re: rear axel [Re: retcon] Dave51Chev Shop Shark Registered: 25/04/11 Posts: 214 Loc: Provo, Utah Matamoros, that's a great question. You should post it as a new topic/separate thread so other's will be able to see it and answer.
Edited by Dave51Chev (30/01/14 12:52 AM) _________________________ Dave Baird 1951 Chevy 3800
Foot starters are for Stovebolters and people who need a kick in the ... Top Reply Quote Quick Reply Quick Quote Notify #1003119 - 30/01/14 07:58 PM Re: rear axel [Re: retcon] 1951Chevy1Ton Shop Shark Registered: 16/04/05 Posts: 419 Loc: Near Sleepy Eye Minnesota Where is Cletus? This is an excellent question from a new Bolter and needs to be transferred to a new post. Top | | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 | If I remember my rear axle on my 1 ton had brackets but nothing on the frame. I replaced my rear end with an 85 1ton rear and trying to come up with a simple solution for mounting. I'm looking at using 85 1ton rear shocks from NAPA, making new brackets on the axle and a bolt in crossmember to bolt them to. Also trying to see if the 85 had mounting brackets that could potentially almost bolt into the existing frame? | | | | | Joined: Nov 2010 Posts: 123 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 123 |
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Dave I tried to PM you but you do not have enough posts yet, call me I have the solution. I will take some pictures for you tomorrow. 801-231-1077 [email protected] I am in Salt Lake (east side). Brad | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I find it funny that they post, solutions are offered and then cue the crickets and tumble weeds? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I don't see any reason why it wouldn't be the same as the 3600 trucks. They used the same frame bracket as what is on the front shocks. | | | | | Joined: Jan 2014 Posts: 6 New Guy | | New Guy Joined: Jan 2014 Posts: 6 | Thanks for the helpful responses. I cleaned up the rear axle jack points and found two holes that I drilled out a bit wider, mounted the bottom of the shock on that and found holes in the frame 48" and 53" back from the front of the bed, reamed those out a bit to accommodate a 1/2" bolt, drilled out two 8" long 2x2 heavy duty square channel, rust proofed that and bolted on top of these a 1" x 1/2" steel "U" about 40 " long running across the frame and drilled holes to accommodate the top of the shocks at a 10 degree angle or so. Works great! Not exactly a ride like my old Jaguar, but better. | | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | I find it funny that they post, solutions are offered and then cue the crickets and tumble weeds? Not everyone is glued to the bolt like some of us. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The brackets in Jimbos picture are the same as those on my 50' 3600. That is the correct bracket that was used as cartridge shocks replaced the lever actions. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | brad any idea what the upper brackets look like and can i get them | | | | | Joined: Jan 2014 Posts: 6 New Guy | | New Guy Joined: Jan 2014 Posts: 6 | I figured out the rear shocks. I got rear shocks from a local wheel shop and found that under the rear axle the jacking point had holes on both sides to accommodate a bolt. I drilled out one hole as the bolt that came with the shocks was a little bigger on one half and bolted it through. Had to do a little grinding but it fits nice. Then for the top mount I found holes on the frame at 48" and 53" and drilled them out a bit and drilled, cut and bolted some 2 x 2 sq tubing to the frame and on the bolt nearest the rear I attached some channel 2" across and 1" high across, drilled some holes for the shocks and presto! it works great and smoothed out the ride quite a bit. | | | | | Joined: Jan 2014 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 32 | My 49 3800 dual rear wheel has the old lever action shocks on it so the axle brackets (which are basically the same on the front and rear) are just a simple whole, basically like a washer was welded onto the axle. The frame just has two bolt holes where the shock bolts on. I can post pics later if you would like. | | |
