| | | Forums66 Topics128,130 Posts1,056,720 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I want to improve the looks of my original 1954 steering wheel as it has accumulated 20 some cracks over it's life. I think it is going to take me several days to restore. So I'm looking for any steering wheel to use during the process. The truck is my daily driver AND I don't have a bike.
If the wheel easily popped on/off I wouldn't need another wheel, BUT, my experience indicates a far less positive experience.
Thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | These wheels pop off pretty easily there are two threaded holes under the horn ring for this purpose. They are 5/16" I believe, blow them out with some air add a couple drops of lubricant and a small puller will have it right off. If you elect to pop it with your knees or a dead blow hammer put the nut back on so you don't lose teeth. You could source any wheel from 1947-59 I believe as a back-up they should all be splined the same. | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Thanks Brad.... That is exactly what I was looking for. I'm plan to see how easy it is to pop off and on again before I get the checkbook out again.
Thanks | | |
