4 members (Hanks custodian, klhansen, Peggy M, 1 invisible), 123 guests, and 2 robots.
Topics128,052
Posts1,055,727
#1007298 02/15/2014 3:13 AM
I have a 1950 GMC 1/2 ton, and just had a differential shop install a new 3.55 gear set, which also included a new oakie bushing. I took the torque tube off the truck and brought them that to install all the new parts in.
When I got the torque tube back from the shop, everything looked good to me, except the new oakie bushing was protruding about 1/8 inch from the end of the tube. I took pictures of everything before I brought it to them, and the old oakie bushing it had was flush with the end of the torque tube (I actually drove the old one out, so it did previously have an oakie install, and both the original front and rear seals had been removed). There are also no rivets or pins on my truck to block or hold the bushing in place.
My question is, is it ok if the bushing is sticking out that 1/8, or will that not be an issue? I did try driving in a little with the small hammer I have, but couldn't get it to move. The shop is a bit of a drive from my house, so if its ok sticking out that 1/8 I wont worry about it, but if its critical that is flush with the end of the tube, I have no problem bringing it back. Just looking for a second opinion on this. I have read on other post that guys guess it will be alright as long as the u-joint slides on all the way. I would assume this to be correct as well.
I can send a picture to anyone if they want to have a look at how far out it sticks.
Thanks in advance,
Jake
1950 GMC 1/2 ton - complete frame off restoration
JakeM #1007367 02/15/2014 7:49 AM
The only problem I see would be if the rear yoke will be prevented from sliding back far enough to clear the back of the transmission and front yoke when raising it into place.
It will most likely work fine.
My Blog
JakeM #1007400 02/15/2014 3:03 PM
Did you try putting a piece of 2"/4" across it and then hammer the 2/4?
Otherwise, heed Dave's advice.
JakeM #1007407 02/15/2014 3:23 PM
I did try a 2x4, actually broke about 4 pieces, the bushing never moved. Then I tried a 1.5 inch impact socket and it still didn't move. I just didn't want to push my luck and smash it to hard and burr it up if it was going to be ok sticking out a bit.
JakeM #1007502 02/15/2014 10:42 PM
Some go in very hard, they may have even used Loctite on it.
I would leave it alone.
My Blog
