Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Southerntruck, Otto Skorzeny), 130 guests, and 5 robots.
Topics128,281
Posts1,058,464
Members48,490
#1006960 02/13/2014 11:36 PM
My 1953 3100 has a 1954 235 in it.
I am refurbing the instruments. Should the oil pressure be replaced to 60 psi and not 30? The temp gauges?
1953 3100
Melbourne, FL
Veteran
Shaanxi #1006981 02/14/2014 12:47 AM
If you can find one. The '54 engine has a higher oil pressure than the dipper 216 had that was original to it.
Shaanxi #1007012 02/14/2014 2:34 AM
49-53 0-60 psi oil pressure gauge
Your 100-220 degree coolant temperature sender/gauge will work in/with the 54 engine/head.
Shaanxi #1007080 02/14/2014 6:10 AM
I left the 30# one in mine. It reads zero when engine is off and is usually pegged at 30 when running. It drops a smidge below 30 when fully warmed up and idling. As long as it continues to do these things, I'm going to leave it.
Shaanxi #1007102 02/14/2014 8:48 AM
Yes. I only have the stickers. I suppose the gauge doesn't care if the psi reads 30 or 60.....it'll peg anyway until I replace the gauge itself.
Steven
1953 3100
Melbourne, FL
Veteran
