| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | My 1953 3100 has a 1954 235 in it.
I am refurbing the instruments. Should the oil pressure be replaced to 60 psi and not 30? The temp gauges?
1953 3100
Melbourne, FL Veteran
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If you can find one. The '54 engine has a higher oil pressure than the dipper 216 had that was original to it.
John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 49-53 0-60 psi oil pressure gauge Your 100-220 degree coolant temperature sender/gauge will work in/with the 54 engine/head. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I left the 30# one in mine. It reads zero when engine is off and is usually pegged at 30 when running. It drops a smidge below 30 when fully warmed up and idling. As long as it continues to do these things, I'm going to leave it.
| | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Yes. I only have the stickers. I suppose the gauge doesn't care if the psi reads 30 or 60.....it'll peg anyway until I replace the gauge itself.
Thanks, Steven
1953 3100
