2 members (Peggy M, UtahYork),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | I want to paint the interior of my 59 Apache with the Comanche Gold Metallic and Charcoal Gray like Jim Karras did with his 59. I PM'd him but he hasn't responded. Does anybody know which of the two colors the gas tank and the heater should be painted?
Thanks!!!
From one of his posts: The following item should all be painted Charcoal Gray:
Steering column Steering wheel column bracket Steering wheel Dash top Dash face above the role Emergency brake handle Emergency brake handle bracket Step well floors Cab floor Clutch pedal Brake pedal Accelerator pedal Bench seat frame and purch Tire jack mount
The item below should be painted in the gold color:
Interior doors Kick panels Dash front Vent covers Door jams
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in my experience with quite a few 55-59 trucks from different plants the gas tanks weren't painted, they were galvanized when made and installed after interior paint - heaters were supplied by Harrison, already painted a hammertone gray lighter than the charcoal just remembered there's a low mile original in the gallery you could refer to, doesn't seem to have a heater, and looks like the gas tank may have been interior color, although it's a Canadian truck Bill
| | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | Thanks Bill! I had to put a new heater core in, so I painted my heater after that, and put the decal on the side. Guess I will cover it up as-is when I go to paint the interior. Getting a new gas tank next week, so I will leave it as-is also.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | The heater box is always painted a hammered finish dark gray. The gas tank will be the gold color or what ever the rest of the inside of cab is. The floor is charcoal gray as are the steps. Some of this is correct http://www.59apache.com/comanche.html
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | Truckrolet,
Yes, that is the site I've been looking at....but I didn't see any pics of the heater nor the gas tank in any of them.....the back wall of the truck is grey, the floor is blue....since the gas tank sits on the floor but is parallel to the back wall, that's why I wondered what color to paint it.... i.e. is it part of the floor or part of the back wall?
Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look at this picture of original parts, gas tank doesn't look painted to me .... and not unusual for a California truck to not have a heater if your floor was blue under the tank, it's not original, floors were dark [charcoal] gray - and if the back cab wall was painted interior color, it indicates the interior was painted before the tank was installed, it wasn't "part" of anything - the tanks were installed when the truck was being assembled, well after any painting on the cab, and as identical tanks went into all different models for 5 different years, with different interior colors, they were the "natural" grayish galvanize color Bill | | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | Thanks Bill.
My truck actually has a black dash and the entire rest of the truck interior is a dark navy blue. It also has black knobs. I am restoring it to the Deluxe version, chrome knobs, two-tone colors. Haven't decided about the seat cover yet. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Iv'e never seen any GM truck with a painted tank from the factory, unless they were installed in the cab before it was painted, and then if any paint was on the tank, it was just overspray around the edges.
The tank in my 45 GMC was like that. The truck was green from the factory & the tank was mostly bare galvanized metal with green around the edges.
| | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | | | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | Nice job!!!! Is that the Comanche Gold Metallic and Charcoal Grey or some other combo?
Thanks for posting the pics, that helps! | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | It's actually 64-66 metallic beige and I'm pretty sure I got it from Jim Carters truck parts online. The charcoal grey is my own concoction of grey and black Van Sickle tractor paint that I mixed up to match the old paint in my interior. The beige was a premixed paint that needs no hardener or catalyst. But I found that when I added hardener it gave it more gloss and made the paint harder. So you can do that if you like the glossier look. The original probably wasn't very glossy. Darren | | |
