7 members (Gdads51, Otto Skorzeny, Wally / Montana, LuckyLee, MickeyP, TUTS 59, kades51),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,705 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | When I got the 48 2 ton the radiator frame was setting on the cross member (wore at least a sixteenth into the cross member} and had 2 bolts hanging through the holes with nothing else.
Question: should be the mounting be-
rubber pad top and bottom, with nuts and washers
rubber pad on top and springs, washers, nuts and cotter pins on the bottom
| | | | | Joined: Jan 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 30 | If its anything like my old M or H there should be a rubber grommet in between the rad and the cross member. If it is such a thing there would be 2 nut with 2 decently wide washers bolting it securely to the member. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Nice to see another tractor person here. Nice Farmalls.
I'd say you need that truck.
Recent restoration projects: '53 ford NAA (Golden Jubilee), '48 Massey Harris Pony W/hyd, '55 Farmall Cub and currently in the works a '59 Porsche 308L Super Diesel. Oh yea, '71 Sears Suburban SS-16 and a '72 GE Elec-Trac.
| | | | | Joined: Jan 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 30 | I haven't seen a porsche tractor in person. Be neat to see one one day haha. | | |
