3 members (55shaker, Stewart2, Leo), 113 guests, and 2 robots.
Topics128,165
Posts1,057,011
Members48,458
I am trying to resurrect an old truck. The fuel and brake lines look good but am wondering if I can clean them by just blowing air through them. Any tips appreciated.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Pouring some solvent through fuel lines doesn't hurt in case there is varnish build up. Not much besides blowing air through brake lines. If rust comes out, its best to replace them.
Thanks for the quick reply.
I like to flush brake lines with alcohol. Get a gallon of methanol (shellac thinner) at the local hardware store or big box store like Home Depot and pump a quart or two through the system with the master cylinder. Then follow with at least a pint of fresh brake fluid, and bleed the brakes as you normally would. Never, EVER put a petroleum-based solvent into a brake system! The residue will destroy rubber parts. Alcohol and rubber brake parts are pretty compatible, and any leftover alky will evaporate.
My 41 manual recommends using ethanol to clean the brake lines. Just find your favorite local moonshine distiller and sample his product. I would recommend that your sampling start with the lines first.
Lots more pictures
Gene, if you're sure the lines are solid you can blow string
thru them with your air gun then as the guys suggest, soak the
insides with alky and pull your twine back and forth in a
scrubbing motion. Somethin' like drying your butt with the bath
towel. That should scrub any cobs loose and help to loosen any
gummy buildup that may have accumulated. I then blow the lines
dry. I do this also with new lines that I've make up, as it
only takes a few minutes and assures that they're pristine
inside.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Paul, why waste good shine? Take a big swig and then blow your breath through the lines! I've got a buddy who grew up in northeast Georgia back in the 1940's who makes something called "Old Huntin' Camp". He says it's "140 proof, aged in glass about 30 days". About 2 fingers in a water glass is enough for the whole night!
Thanks everyone will give this advise a go! I even have some moonshine to sip on while I do this. And I think it came from GA actually. LOL
