| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | my question is: I have a 46 1/2 ton chevy truck and I need to replace the steering box, I've been told a vega steering box will bolt up to my frame,now,I have the motor out of my truck and im looking at the original box, and it looks nothing like a vega box, CAN anybody tell me that it can be done without drilling and fabrication, and it bolts in?? any input would be appreciated | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Vega strg. boxes are used on a lot of street rods. To put it on an old truck would take some modifications namely the steering column. It would not be worth the effort. The original box will work good if it is in good condition & adjusted right. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The Vega box is not heavy enough for your truck either. Nothing is a bolt in, its going to take some fabrication. Speedway Motors has a good selection you can look at. www.speedwaymotors.com | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is almost no difference in the design of the working parts between a Vega and a 1941 and later truck box. They are both reciprocating ball design. If your 46 box is in good shape, or rebuilt, it is an excellent box. I have put 1941-46 truck boxes in 1939-40 trucks many times because they are such a good box, and a simple bolt in for anyone wanting much improved steering.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I agree with Dave that the original steering box on your truck is a good unit. The Vega boxes come in 3 different ratios, 22:1, 20:1 and 15:1. The stock Vega box I think is 22:1. Another problem the street rod guys have is the different pitman arm lengths. Both of those can make for miserable steering. The Vega weighed in at a little over 2000#, your truck is heavier than that. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | thanks guys for getting back to me before I spent the money for a new box, I think Im just gonna send this one out for a rebuild | | |
