1 members (Otto Skorzeny), 95 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
i am a novice mechanic still learning. (really a parts changer so as not to offend you seasoned guys with the nature of this question) i am familiar with these basic terms from working on my honda accord.
cap,rotor,distributor cap,alternator,timing belt etc.
i am not however familiar with the terms used concerning these old trucks - coil,condensor,points,generator,regulator etc.
are these anchient terms for modern components?
thanks for your help
the distributors on these ol thangs require a seperate coil to provide the spark, it hooks to the distributor via the center wire on the cap - the condensor lives inside the distributor as part of the spark control, and the points are the contacts in the distributor that open and close to put spark to plugs as the rotor gets to each terminal point ..... a generator is the old version of an alternator, and it takes a seperate external box, the regulator, to control its output, whereas yer alternator will be internally regulated
the \'engine electrical\' part of the shop manual has lots of pictures and explanations
They're ancient terms for ancient components. grin
Nowadays, if there's a distributor, it's electronic (HEI, usually), and there's not a whole lot you can do if it goes bad, except for replace the module. It's "easier" (i.e. less to do), but quite a bit more expensive.
The old Distributors are pretty simple. There are many parts that can (and should) be replaced periodically. Bill has things pretty well spelled out as to what all the little pieces-parts are.
The Generator is the old version of the alternator. They work differently (the alternator generates an AC current which is rectified into DC internally whereas the generator puts out a DC current right from the get-go) but do the same basic thing. The reason alternators are more prevlent nowadays is that you can get the same amount of charge whether you're sitting at idle or driving with the engine pegged out. With a generator, the higher the engine revs, the more juice your generator puts out... Which is where the regulator comes in. The regulator keeps your battery from overcharging when you've got the engine running at a higher RPM rate.
Most alternators are internally regulated as well, but some of the older ones use an external regulator like the generators did.
Have a peek at the shop manual, and if you'd like some pictures on how the thing works, I can take some tonight when I get home.
