1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Can anyone tell me if the seat from a 54 will fit a 51? They look the same, but before I try it, I thought I'd ask. John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The same conventional cab seat frame and seat cushion was used from 51-55st. If you have an early 1951 truck, there is a slight possibility that the older seat frame might have been used until the factory ran out of them. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From what Brad has posted, it looks like the change took place in 1950, with 1951 being the first full year with the newer style frame? | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks for the info. I just didn't want to pull two seats apart for the practice. My 51 was hacked by a PO to put speakers under the seat. John | | |
