0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 22 New Guy | | New Guy Joined: Aug 2009 Posts: 22 | I am putting a 6.0 in a s10 frame with a 49 Burb body. This post question is about mounting the motor in the s10 frame. Are the motor mounts symmetrical on the 6.0? It seams that when the motor is in the frame the motor sits at an angle. And to level the motor, one mount has to be taller than the other. Is 1 mount higher than the other on the block? It appears the frame where the motor mounts is like all the others at the cross member. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I assume that your working with a LS motor. They are making motor mounts to put LS motors in older chassis. | | | | | Joined: Aug 2009 Posts: 22 New Guy | | New Guy Joined: Aug 2009 Posts: 22 | It is a LS motor and I have the plates that bolt to the block to locate the motor to the correct location using the standard three bolt motor mounts. I am wondering if the block is different at the mount locations. Like if one would need a longer frame mount on one side. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Which are the plates you have to locate the motor to the "correct location"? Are they specifically meant for an AD truck on an S-10 frame, or are they for an S-10? The reason I ask is because those 2 applications need the engine in much different locations.
It's possible you might need a longer frame mount on one side, I don't recall how symmetric the S-10 crossmember is. Since you have the engine, it seems logical to check the parts you have and see where the issue is. | | | | | Joined: Aug 2009 Posts: 22 New Guy | | New Guy Joined: Aug 2009 Posts: 22 | What the plates do is locate the LS motor in the location where a small block would sit. The problem I had is a friend kept making frame mounts to mount the motor when I had bought a EZ Swap kit that included frame mounts to locate a v8 engine in the right location on a s10 frame. The friend said he had to make them because the LS motor had irregular or uneven motor mount locations on the block, like one side wasn't like the other like regular small blocks. But by my measurements and naked eye I couldn't see any difference in the mount locations in either the motor or the frame. I've known this guy for 30 yrs so I believe him but I can't find anyone that confirms what he is saying.
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | What did Ed at E-Z chassis swap say, he usually has a good handle on that stuff. My understanding is the 6.0 drops right on the 5.3 mounts just fine. Mongo | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I realize what the plates do, I was asking if they're for use with an S-10 body or AD body on an S-10 frame. The two applications are much different.
I don't believe that the LS motors are non-symmetric. That makes no sense. | | | | | Joined: Aug 2009 Posts: 22 New Guy | | New Guy Joined: Aug 2009 Posts: 22 | The plates were actually intended to be used on a 68 Chevy Truck. And I agree it makes no sense. They certainly appear to be symmetrical. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If the plates were to be used with a 68 what's the sense in using them for your truck? Since you're doing a custom installation anyways, you might as well just start from scratch? | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 |
| | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | Are they giving gas away in Carolina or are you stealing it?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What engine did the S10 frame have it originally? V6 (2.8 or 4.3) or 4 cylinder? That could very well be part of the issue, the mounts in the frame not lining up properly.
Bill Burmeister | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | I have mounted a 6.0 liter (in a '70 Impala) and the mounts are on the same location on each side of the block. Even a good, 30 year friend can be wrong, sometimes... Do a google search, plenty of results, such as : http://www.s10v8.com/store/LS1-LSX-Mounts-Headers-for-S10-V8-ConversionAlso, try asking your questions on the LS1Tech forum, they have done everything with these engines!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Just make sure you don't put the engine where it needs to be for the S-10, as it will be in the wrong place for your burb. | | |
