5 members (Donf, Woodcmiami, Jon G, 1955 1 Series, lumbersawyer), 115 guests, and 7 robots.
Topics128,269
Posts1,058,398
Members48,485
#1005322 02/08/2014 5:12 AM
My truck has the die cast frame, does the correct gasket come with holes in it for the screws to pass thru? I believe I was sold the wrong one because it covers the holes and there is no way to mount it. I double checked the Steele part # and it matches the application, but there is no way it can work. Also what are you guys using for the cloth tape between metal body parts? Thanks, Scott
Scott,
The new rear window gasket I got from Steele Rubber did not have the holes for the screws nor were the ends vucanized. I cut the gasket to fit the glass, taped the gasket to the glass and then placed the glass/gasket assembly in the cab opening. I made sure the assembly was centered adequately, and then had someone mark the screw hole locations from inside the cab. Once I had the hole locations determined, I used a freshly sharpened gasket hole cutter to make the perforations. The process worked out fairly well.
Paul
Lots more pictures
My gasket is 1/2" thick and one piece, does that sound similar to yours? The seam is vulcanized on mine, and the OD is exactly the same as the frame. Scott
It sounds like you got a better part, I had to glue my gasket as it was not vulcanized. I would say that the 1/2 thick part and size to the pot metal frame sounds right. I used a paint marker to locate where to punch the holes.
Paul
Lots more pictures
I'd love to see pictures, from both sides, once you have it installed.
I will make an attempt to get some images posted.
Lots more pictures
Here are a couple of images of my rear window. The civilian application would be the same less the back window guard.
http://www.surfacezero.com/g503/sho...p;title=2014-02-13-11-31-21&cat=3722
http://www.surfacezero.com/g503/sho...p;title=2014-02-13-11-30-12&cat=3722
Lots more pictures
Did you use any sealant? The hole punch worked great! Thanks, Scott
Scott,
I used some bath and kitchen type sealant that can be cleaned up with water. I CARFULLY injected a small bead around the perimeter, and then wiped most of it away with paper towels/rags. I finished the process by wiping the area with a damp sponge cleaned often with water until all of the sealant residue was removed.
Yeah the gasket punch sure did work for cutting the rubber. I tested drilling the holes, and don't think it would have worked as well. I don't know about you, but I was glad to have the rear window task behind me.
Paul
Lots more pictures
Moderated by  ndkid275, Phak1
