2 members (ShopRag, DaveV),
97
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | good morning to all, i finally got my 37 suburban but have some questions that i hope you can help me with:
1. where and how does the gas tank mount too? 2. whats the deal with the granny gear? how do i use it? im used to the regular older style where its 3 gears.
thanks sorry for the newby questions. | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Granny gear is First in a 4 speed tranny-- and is located by pulling lever to the left and then forward ( where you would find first gear on a 3 speed tranny).Reverse is the tricky one to find-- it should be all the way to the right (it is spring loaded and needs a strong push)then either toward the seat or toward the dash (sorry I don't remember which way but you will feel it move into gear). | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Granny gear is First in a 4 speed tranny-- and is located by pulling lever to the left and then forward ( where you would find first gear on a 3 speed tranny).Reverse is the tricky one to find-- it should be all the way to the right (it is spring loaded and needs a strong push)then either toward the seat or toward the dash (sorry I don't remember which way but you will feel it move into gear). grandpaglenn, when you say (where you would find first gear on a 3 speed) didn't you mean to say where you would find first on a 5speed? First gear on a 3 speed is left and back to the seat..isn't it? | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | thanks..i got the gas tank mounted me and my son all i got to do is connect the fuel line.. as for the tranny once i get her running we are good for testing
