0 members (),
56
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I would like to make my own tailgate support chains. I have a new tailgate. In fact the truck has new paint and just about finished at the body shop. I'm sure someone here has some tips as to what to use, or does it make more sense to just buy a set? Along with the chain size and ends, what are folks using for the protective cover? I think something flexible but durable?
thanks much. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I'm with Brad on this one. To make my own would wind up costing more the new parts.
Back to the drawing board. My truck has been in the body shop for some time now. It's due to be complete in a few weeks (body shop time that means by March) so just getting the last few things needed.
Thanks much.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I'm with Brad on this one. To make my own would wind up costing more the new parts.
Thanks much. That "Indian Carrying Rack" in your photos is quite the unique piece! | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I am guessing you are keeping it all original. But I think I saw ads on tv for the new GMC's that have cylinders on the tail gate. Guess this would let them down easy without having to hold them up. Thought that might be neat for an older truck.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Yea, thanks, but I'm staying as close to original as practical. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Those chains will scratch your new paint, I saw somewhere a bracket that bolts to the side of the tailgate and the side of the bed that folds as you open and close the taigate like on later vehicles. If I were doing it again I would find something other than the chains.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Yea, thanks, but I'm staying as close to original as practical. At this point, with the truck already at the body shop, you are pretty much limited to slip on covers. When it comes to tailgate "hooks and chains" the only method that will ensure that the paint doesn't get scratched from the chains swinging, and chipped from the hooks going through the holes is if you: 1.0 Don't drive the truck - AND - 2.0 Don't open or close the tailgate. So if original is you're preference then you'll have scratches and chips... it's pretty much the nature of the beast.  | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Or you could dip the chain and hook in some 'tool grip'rubberized goo from time to time. Might look better than the chunk of garden hose I saw on most of these tailgates...
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I read a tech tip somewhere where someone used a bicycle tire tube that tightly fit over the chain. It made it so that the chain was stiff and wouldn't easily move around and scratch the crap out of your paint. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | But that chunk of garden hose was what GM supplied them with, it's the original look.
dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Just remove the chain completely and use 2 of those pins with the finger ring, like is used to pin farm equipment with a 3-point hitch. Similar to hood pins on hot rods. They are only a buck each at a farm supply. But when you let it down, there will be nothing to hold it up level.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think it'd be pretty tough to get a piece of garden hose over the hook - and I seem to recall from the dim past the originals were a coated/treated fabric of some type .... I've always used 10 speed bike tube pieces on the chains, fairly easy to get over the hook and flxible enough to work well (....) But when you let it down, there will be nothing to hold it up level. most trucks originally had no back bumper, so that wouldn't be a problem  Bill | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | How about Silicone Rubber Tubing? Super soft, threads over the hooks and fairly inexpensive... McMaster Carr P/N 5236K98 1-3/8" ID, 1-1/2" OD, available in Black, Red Blue and Opaque http://www.mcmaster.com/#standard-silicone-rubber-tubing/=qkd355 | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I believe from my research that they originally did not have a bright plated finish, but rather a dull black finish. I am basing this on this unrestored, original paint '49 GMC 49 tail gate chain and the remnants of the original finish on the chains on both my '52 GMC and '50 Chevy trucks. Here is what I did with the original chains on my GMC. 52 GMC tail gate chain I used Ospho to restore the black phosphate finish. You might be able to use Naval Jelly to accomplish the same black finish. The cover is from Jim Carter and looks just like the original complete with the ribs and drain holes. cover
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | But that chunk of garden hose was what GM supplied them with, it's the original look.
dg Sure it's the original look, but other solutions will probably hold up and protect the paint better (and even look better). My and others' comments on that were based on protecting the paint, not on originality. It's the owner's choice ultimately. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I thought originality was one of the objectives of the original poster. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Well shoot... I read the OP's first sentence wrong (sorry Dave). I thought he wanted to manufacture his own (original) chain set and Now what's a guy to do? Ya got yer chain ya got yer hook ya got yer piece of rubber hose (which thanks to Denny is now Original and so unavailable for Dave's 'original' purposes as that would make it a copy) Paint the chain and cover it with clear plastic hose?
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | How about using a bicycle inter tube cut to size as a chain cover? Looks great and is cheap and readily available. Jerry Jerry
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Use what they used originally and let it get chipped. That way it will take away some of sting when somebody opens their door into your new paint job. The second scratch is never as painful as the first one. Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Think that's what Bill posted earlier Jerry. And Bill, the protector slides over the chain opposite the hooked end. DG
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
What color was the protector?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, if you have the chains on the bench anyway Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Can't document it Tim, you're much more of a perfectionist, also, I lost my hard drive last year with all my reference material on it so it's like I got a lobotomy, but all I do remember seeing were the black ones, that look just like the ones Huck has linked to on his 52. Think JC and the other repop guys got it right on this one.
One nut Bill, taint all that much of a problem for the average back yard mechanic. DG
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Denny
It looks like some of the pre-54 illustrations had covers that were not black-dark. It just might be artists' poor renditions.
Black suits me fine for the yellow/white 54 pickup that I am working on. It had a lot of black "accents".
As you posted, installing/replacing the rubber is not much of a problem.
| | | | | Joined: Jun 2009 Posts: 785 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 785 | Can we conclude that the A.D. tailgate chains left some assembly plants with a zinc/galvanized (CAD?) finish (per Tim), and other assembly plants used chains with a dull black finish--due to phosphating (as reported by HUCK)? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not conclude the pick-up box tail-gate/end-gate cable came zinc/cad/galvanized, nor do I disagree about a black finish (which I would prefer). "I think the original were zinc/galvanized plate", but I would not bet (or disagree with anyone) on any possibility.
Also, my experience is only with 1954 - the pick-up box end-gate/tail-gate chain assembly changed that year. I have no doubt that a cover was available in 1954 (and, I assume that a cover was available/used in earlier years, but I cannot find documentation for that).
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Again I have no way of documenting it, but I'd bet the farm that the chains always would have had a cathodic or galvanic protection such as zinc, cad or galvanizing. A phosphate coating really would not offer much protection for very long.
And solid black doesn't show up very well in an artist rendition Tim, so I'd be a little skeptical about that as proof of color for the protective sleeves. It's to bad that color photo's weren't popularized till the late 50's, we sure could use some for documenting true factory color. Most of the slides and color photos that I took in the 60's and 70's are badly faded even though I've kept them cool, dry and out of the sunlight.
Denny G.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, George,
Maybe someone will post similar information about earlier chain assemblies.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now remember, we’re all part of the big show, we’re on in ten seconds so get ready to have a good time, all right, here we go……this is exciting isn’t it! 10….5,4,3,2 now let us imagine that we’re standing behind the parts counter at Phil O’Keefe Chevrolet in 1977 and you’re in the middle of the afternoon. This guy comes in with a request for a new set of silver chains for his 1953 pickup truck. Now he’s not very happy when you drop the set of black chains on the counter. Sad news is they’re the same part number and have replaced the earlier plated ones??? So, with the ammunition that George and Huck has supplied us with and with a couple of pages out of our May, 1977 parts book that we have on the counter, it looks like my explanation to my customer will be that the chains up to ’53 were plated and after that they only came with the black oxide or is it paint? Huck, my guess would be that your chains were replace at some point in the 60 year life of you trucks and that’s why they had the black ones on them. George, the trunnions must have been miss labeled since they don’t have anything to do with the chains. They are actually for the pivot point of the end gate. Also the later revisions moved them to gp. 17.208 and the chains to gp. 17.225. Also if you noticed the listing for the covers, they were available in black or inca silver most likely to accommodate the later trucks. http://www.pbase.com/dennygraham/image/154412618/originalhttp://www.pbase.com/dennygraham/image/154412619/originalI think Tim is correct, along with the changes in the body for '54, in preparation for the big body style change later in '55, there were a lot of minor changes in the parts supplied as replacements. Such as the elimination of the plated chains and the addition of the silver covers. Denny Graham Sandwich, IL
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Denny G., Before I purchased the tailgate chains on ebay. I showed them to my internet friend W.D. Foster, may he R.I.P., from Keller, Texas. W.D. was a ( 10 or 11 ) state regional sales manager for G.M. ( retired ). W.D. had a restored '55 1st. series truck. He told me to buy them..., quote from WD, " they are correct for your '54 3600 "
I learned from W.D., that galvanized chains were correct & the '54's had BLACK rubber covers. It's not etched in stone, but W.D., sure seemed to know his stuff. I purchased many rare GM NOS parts from him. He never steered me wrong. Photo of WD @ photobucket http://i669.photobucket.com/albums/vv57/glp0329/WD%20Foster/WD_Foster__zps97093ef9.pngGeorge in New Jersey
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | George,
If WD said that, I'd take that as gospel.
Thanks, | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | '54 could very well be the turning point George, or '55 or '56 for that matter. It just seems logical to assume that when GM was switching over from fat fenders to their cubism design that many changes were taking place. That mid 50's period of time is filled with much uncertainty. The later parts books, mine as shown in the link, was a May, 1977 revision, list the same number from '54 thru '72. Just because the parts book list's them for those years does not mean that the original ones came with a black chain. That could have started in any year, the parts book is for "replacement" parts, it never guarantied that they would be exactly like the factory originals, just that they would fit like the original parts. In fact if I recall correctly, at one time GM only specified that replacement parts would only be guarantied for 10 years. Of course many of the parts fit the same application for many decades.
DG
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Tim,
I went back to my saved email archives folders. I found the email from W.D. .
as in his email: " they are correct for your '54 3600 "
Therefore, I edited my post to reflect exacty what he said.
Thank You for your insight. I always enjoy reading your posts. The same goes for Tim's posts.
There are some real sharp cookies here on stovebolt.
That's why I try to participate.
Denny G., I'm sending you an email concerning the installation tool you made for the installation of the 3rd. gear bushing on the SM 420 - 4 speed. I've been trying to find the original Kent Moore tool......with ' no luck ' . I'm asking, would you be willing share the measurements of the tool you made ? Maybe, I can have one made up . Unless, you made up more than one & would sell it to me.
George in New Jersey | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I had a '75 Chevy stepside, it had black covers over the chains. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It was quite some years ago that I did that rebuild. If this is what your talking about George, then its just an aluminum guide bushing that fits over the end of the shaft and the outer sleeve is the same, just a piece of aluminum tube to push the bushing in place. I think I just spun them both down on my bench lathe: http://www.pbase.com/dennygraham/image/137529725/largeIt's really nothing special as are the other "special" tools to disassemble or assemble the SM420. One can actually get by with a light hammer and soft punches. The material that the sleeve's were made from probably got used for some other project when I finished the SM420 rebuild. I went to a lot of trouble to make the rear bearing puller and in the end it pretty much just slip fit out of and into place, no real need for the fancy puller. Disassembly/reassembly of the three speed is the same case, you can get by with the simple tools that anyone has in their tool box, no real need for the special tools shown at the end of the chapter. In my youth I went thru a lot of three speed transmissions because of speed shifting and never had any thing special to work with. Even loaded the clusters with out the tapered pin that they show by using heavy grease to hold the needles in place. Denny G
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As I posted above, in 1954 the style of the chain assembly changed.. Note that a cover is shown for 1954, but is not shown for earlier years. What's up with that? | | |
