2 members (2 invisible),
87
Mod | | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | How is the best way to remove a dent from the stainless steel outer shell on the glove box door?
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | For a small dent I would try drilling a small hole on the back side in order to get a tool like a punch in direct contact with the dented area and try working the dent out with just hand pressure pressing against the dent. If that didn't work I would try light hammer taps. Once the dented surface has been raised flush you can file, sand and finally polish the stainless to look like new. Then fill the hole on the back side and repaint it. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | What is it anyway that so many of the glove box doors are dented. Mine has a dent as well. I decided to purchase repops (both speaker grille and glove box door) so that they match each other. My original speaker grille was beyond repair.
BTW, I like the idea of drilling a hole in the back side. SS is tough to work, so mileage may vary. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Mine were all dented, too. I think they became foot rests and knee rests over the years…or, got smacked by flying cargo sitting the seat or on the floor.
I had to buy replacements, too …due to the radio section being cut up. but, I did manage to make the glove box door look less lumpy for a "driver" | | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | What is it anyway that so many of the glove box doors are dented. Mine has a dent as well. Mad ole lady.
| | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | I carefully bent the flanges up and slid the back and the stainless front apart, straightened the dent and put it back together. It was'nt to bad of a fix
above all this old truck has taught me patients!
| | | | | Joined: Jul 2005 Posts: 21 New Guy | | New Guy Joined: Jul 2005 Posts: 21 | I drilled a really small hole in the back then hit it with some high pressure compressed air. It popped out and looks good as new. | | |
