4 members (HandyAndy, Phak1, Otto Skorzeny, mo2cyl), 89 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#1004482 02/04/2014 8:24 PM
1 Offline
Hey, I've done some research on trying to find my engine block serial number and have looked for it where the site say it will be however, I still can not, for the life of me, find it! Would someone be able to assist me a bit? Maybe with some photos? Thanks!!
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
On the pad to the rear of where the distributor goes into the clock.
If there is no code there, it might have been ground off or it might be a replacement engine.
1 Offline
The plate looks clean. I gently ran a wire wheel for only a few seconds to get off whatever gunk the wire brush couldn't get and I can't find any numbers. Is also doesn't look like they were grind off either. Just looks like they were never there. Now this is a 1942 built January or '42 I don't know if that makes a difference? I haven't tried looking for those other numbers yet. Here's a photo
http://i1298.photobucket.com/albums/ag41/Steve_Pfost/photo19_zpse7714907.jpg
Try also looking under the push rod cover, the number was likely also stamped on the block, above and to the right of the distributor.
1 Offline
Okay I will try and look for those. The engine is full of gunk and it's hard to check for these number with the fenders and all that still mounted. I may just have to wait.
1 Offline
I scraped away some gunk today and haven't had much luck with full numbers HOWEVER, I found what looks like GM and a large 48 with a circle around the 48. right to the right of the distributor. Has anyone ever seen this? The GM and 48 are about as large as a half dollar.
Ex Hall Monitor
Ex Hall Monitor
I believe GM shipped replacement engines with no number. It was the responsibility of the installing shop/mechanic to stamp the necessary numbers. That often didn't get done.
Picture of a NOS block to illustrate what Tiny said, pad is unmarked. I mentioned earlier I bought a 48 GMC parts truck that was simply stamped 248.
https://www.flickr.com/photos/advance-design_parts_co/13994062018/in/set-72157631868452754
The GMC 270 in the 54/55 GMC COE that we are "restoring" is a factory replacement engine. All that is pressed into the pad is "270". I do not know what (if anything) the Chevrolet factory replacement engines had pressed into the pad on the block.
The 235 that came in one of my 54 Chevrolet pickups had a donor replacement 1954 engine that has the engine serial number crudely ground off of the pad.
