1 members (Stovebolt48), 73 guests, and 6 robots.
Topics128,021
Posts1,055,352
Members48,420
#1004517 02/04/2014 10:56 PM
I have a 1948 1 ton panel and trying to find out what rear end I have. I was told to take off back cover and count the teeth in the ring gear. I did and have 32 teeth. Not sure if it is a 4:11 or 4:56. There was another gear but not sure if it was the pinion but it has 18 teeth.
Thanks for any help.
first48 #1004522 02/04/2014 11:17 PM
' Offline
Your rear axle is a 7 to 32 ratio which equates
to a 4:57 rear.
The ( 18 ) toothed gear you saw was a differential
side gear & it has ( 18 ) teeth.
I have a eaton rear axle in my 1954
Chev 3600 the same as yours, I do believe.
The pinion gear has ( 7 ) teeth.
Photos @ photobucket
Pinion Gear
http://i669.photobucket.com/albums/...ar%20axle/PinionGearNOSx_zps316f0529.jpg
(18) tooth - Differential side gears
http://i669.photobucket.com/albums/vv57/glp0329/SideGearsNOS_zps5e488d23.jpg
4:57 Ring Gear
http://i669.photobucket.com/albums/vv57/glp0329/RingGear2_zps6dd10b3b.jpg
Ring & pinion
http://i669.photobucket.com/albums/vv57/glp0329/RingandPinion4_zpsc517c2d7.jpg
I've collected every single part inside the
rear axle housing - GM NOS
If you need any photos of any part
in the rear axle...I can supply them
to you.
George
in
New Jersey
1954 3600
Now cruising in
The Passing Lane
