7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 7 New Guy | | New Guy Joined: Jan 2014 Posts: 7 | whats up guys im mike, still pretty new to this forum though ive tried searching the topic because im not new to forums in general lool.. couldnt find enough information so here we are. first of all i have a theory as to why this happens with these engines. im talking of course about cylinder #1 going out of round at the upper section right behind the water pump.
from what i can tell every other cylinder is wearing evenly in both of these 250's ive torn apart so far.
one is a pre 75 non emissions that had been at least taken apart and freshened up at one point from what i could tell by the gasket maker and the driver side cracked head bolt hole behind water pump indicating he should have used head studs lol.
other one is a 1979 integral with a clearly longer service life with some possible neglection as well but overall not terrible for 80 dollars.
both engines seemed to show even cylinder wear on cylinders 2-6 but the same type of tapered wear focused mostly on the area directly behind the top of the water pump impeller. from what ive read people claim the number 1 cylinder runs hotter than the other 5 and im not so sure thats the case. with even wear on every other cylinder that would indicate a consistent temperature change throught the entire cylinder allowing for evenly dispersed slow enough for safe expansion and contraction. with the water pump pumping cooled water directly onto that upper portion of the cylinder wall it causes that upper portion of the cylinder to not expand to quite the tolerances as the rest of the cylinder promoting increased friction and wear inevitably egging the cylinder out.
this is my theory and im more than ready to entertain any other ideas or findings on the matter. i dont yet have any exact measurements, i need a good, painless, and accurate bore gauge for about 50-60 dollars or less as long as its a good product! but i am concerned about this problem because on the 79 integral motor the edge created from the wear appears to be close to .030 deep and the engine appears to be completely standard. it just sucks i got that other engine that looks beautiful inside, and the block is cracked.. i just hope the 79 block is useable because though the engine may come cheap its still annoying to have to find another engine for the right price in hopes its unmolested and rebuildable.. any insight is greatly appreciated and entertained. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have put a lot of thought in this. I have been at this for 60 years & have found #1 cyl. wears more then the rest on practically all engines. I don't know why. Maybe Hot Rod Lincoln will chime in. He has a lot of theories. The crack in the block has been a problem around the front head bolt on the drivers side. The factory has revised the torque specks to 85 lbs. on that particular bolt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | This theory has been around awhile, there is nothing that can be done about it.
Look for a 292, that will solve the cooling issue of #1 cylinder, at least the top of the bore issue's.
Joe | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The number one cylinder has always been the one to show wear in our Cummins Diesels. And this is a history that spans 50 years and as many as 20 trucks running at a time. We have always attributed it to the fact the number one cylinder is the last to get oil. If bearings and cam bushings start getting excessive clearance, the no one just doesn't get enough oil. We recently lost a N14 due to a run away and it was the number one rod that spun. I also have an ISM in the shop right now that is a high miler and it is the number one that is low compression due to blowby. We didn't bother to mike the bore because we installed 6 piston packs that come with wet sleeves. No engineer has ever told me that this is the reason, but all of the old time mechanics that I have known over the past 60 years pretty much shared the theory. | | | | | Joined: Jan 2014 Posts: 7 New Guy | | New Guy Joined: Jan 2014 Posts: 7 | the place that will wear out of spec the fastest is the place that the temperature fluctuates rapidly most often. its clear there wasnt much thought put into the design of the water pump jacket in terms of directing the flow of cold water a little bit smarter... so you say the 292's dont have this issue? is it the water pump that sets them apart or is the water pump housing designed differently?
id like to stick with the 250 if i can as im already strapped for space as it is with that s10 so im in no hurry to switch to the 292... BUT, i want a reliable engine that wont lose compression on that #1 cylinder while every other cylinder wears within a limit leaving me with a lousy engine after possibly only 1/3 of its potential service life... has there been any tricks to redirect the water? or possibly even a secret thermostat, rad, and e-fan set up to keep temps as consistent as possible? | | | | | Joined: Jan 2014 Posts: 7 New Guy | | New Guy Joined: Jan 2014 Posts: 7 | what cummins engines are you speaking of? generally the first slug to see lube is the one closest to the oil pump and generally the oil pump is an accessory driven at the front of the engine somehow. generally if its an oiling issue you will have scoring rather than excessive taper. | | | | | Joined: Jan 2014 Posts: 7 New Guy | | New Guy Joined: Jan 2014 Posts: 7 | forgive me, i missed where you said n14. so wait, how did the engine run away from a spun rod? or are you saying that was the result of the runaway? what exactly caused the runaway?
also, may i ask where you learned #1 cylinder is oiled last? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I know the number 1 cylinder on my 230 had a "bump" in the front of the cylinder wall. We figured it was caused by someone trying to install to long of a bolt in the water pump at so time. Anyway my uncle used a ridge reamer and cut the bump out and the engine was reassembled. Still running good yet today.
John | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | The cold water theory has been around forever and couldn't be more incorrect. True, all the 230 and 250 engines always seem to have excessive wear in the front cylinder. We raced them for 25+ years and have consulted with top GM engineers back in the 80's about this problem and what was told to us was this. It comes from a "green" cast block, coupled with the fact that the front cylinder inside the water jacket is machined for the water pump impeller causing the cylinder to "relax" or stress, and not stay round. This along with a short head bolt on the driver side deck, fails to correctly pull the cylinder round and hold tension as time passes. Its like when you only machine one side of a piece of steel and it curls like a banana, this is what happens to the cylinder when only the front face is machined for the impeller clearance, plus it is now much thinner than the rest of the cylinder in the front portion. After a block becomes seasoned and is rebuilt years later, it will not do this anymore, or at a minimum unless the front head bolt issue is resolved, and then all 6 cylinder will wear more evenly.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | I've encountered this problem on two 250's, and the fix can be pretty simple. Bore the block for a 1/8" wall sleeve in the #1 cylinder, and machine the water pump impeller back just enough that there is no interference with the sleeve, in case it rounds out the part of the cylinder where the milling was done. We also did something similar on Ford 2300 OHC 4 cylinder engines when boring them out .110" for 307 Chevy pistons. The front cylinder ended up paper thin where the pump impeller machining was done, so we always sleeved that hole first and bobbed the impeller for clearance. Jerry
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | I've encountered this problem on two 250's, and the fix can be pretty simple. Bore the block for a 1/8" wall sleeve in the #1 cylinder, and machine the water pump impeller back just enough that there is no interference with the sleeve, in case it rounds out the part of the cylinder where the milling was done. We also did something similar on Ford 2300 OHC 4 cylinder engines when boring them out .110" for 307 Chevy pistons. The front cylinder ended up paper thin where the pump impeller machining was done, so we always sleeved that hole first and bobbed the impeller for clearance. Jerry Dang Jerry, that's some high tech stuff there! I always pay attention when you chime in, but man you know your stuff.
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Thanks, Carl! Those little 2300's sounded like a bumblebee on steroids at 9500 RPM on a 1/4 mile dirt track! We ran them in the "Outlaw Mini-Stock" class in Pinto and Mustang II bodies. Jerry
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Ennjunz, this is getting way off topic, but the N14 broke a shaft in the turbo, which is not commons, but it happens when you log several million miles a year. Although the driver had been driving a truck for over 20 years, he had never heard of a runaway. With a broken shaft the turbo sprayed oil into the intake and that created the runaway. With all the smoke, the driver thought something was on fire and called the fire department instead of putting it in Hi gear and dumping the clutch. The engine ran until it was out of oil, the No.1 spun, the rod stretched and the piston hit he head. They say bad luck runs in 3's. We actually blew 3 turbos in 2013 and they all were Cummins Recon. Not some of the Chinese aftermarket that are around now. | | | | | Joined: Jun 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 56 | ... but it happens when you log several million miles a year... I just have to ask... I hope your not referring this many miles for one engine, because that is mathematically impossible.
1947 Chevy 3100 - Shop truck - 250 L6/T5/4.10's 1970 Chevy Camaro - Rotisserie jail
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | that is mathematically impossible. When the guy owns several dozen trucks, it's very possible- - - - -gotta know the players around here before you start questioning their statements! Jerry
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Didn't this all start out as "how dependable is the 250," kind of? While it is probably nowhere as well designed as some of the modern engines or most race engines, but it is well designed enough that a stock, well used 250, under my abusive driving style, went from 150k to 326k when I sold it. The new owner put another 80k on it before it started to get really tired. And I have it back! I had already planned to do what Jerry suggests when I have the block bored. The point is the 250 is good enough to go 400k if you keep oil in it and keep it reasonably cool. It isn't a big, shiney powerhouse, but it is the modern essence of the STOVEBOLT engine! Dang things run forever!
keep on truckin'
Les | | | | | Joined: Jan 2014 Posts: 7 New Guy | | New Guy Joined: Jan 2014 Posts: 7 | thats good to hear. the engine pre 75 was said to have 140,000 on it and the cylinders were worn in maybe .005 throughout the stroke with a minor amount of taper on cylinder one as opposed to the 79's cylinder 1, so i can imagine the 79 integral motor with significant taper on cylinder one had a mass amount of miles.
i will know whether i can use the block or not once this eastwood tools bore gauge arrives in mail. i feel ill be able to salvage it and run .060 over but ive read that is stepping into the realm of cooling problems? ive also heard of people getting away with .125 over so i dont know what to think.
i can see how a freshly cast block would promote that type of wear compared to a seasoned block thats seen so many heat cycles so feel confident in being able to build a strong 200k+ engine out of this 250. im very excited to see how well it performs in this s10 with a 700r4 behind it.
if theres any mpg/economy gurus on these 250's please feel free to share any valuable information you may have!
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Going to .060" over is pushing things a little. I'd very much prefer .040 over if that's an option. Definitely consider sleeving #1 if it's got more taper wear than the other cylinders, even if you only go with the thinwall 3/32" sleeve. One sneaky trick is to use 307 V8 pistons- - - -they're flattops instead of the 1/4" dish top that the 250 piston has, and every other dimension is the same, bore size, compression height, wrist pin diameter and weight. I've also milled the head on a 250 engine .050" without having any piston/valve interference problems. With the flattop pistons and a milled head, the engine really comes alive. Jerry
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | Going to .060" over is pushing things a little. I'd very much prefer .040 over if that's an option. Definitely consider sleeving #1 if it's got more taper wear than the other cylinders, even if you only go with the thinwall 3/32" sleeve. One sneaky trick is to use 307 V8 pistons- - - -they're flattops instead of the 1/4" dish top that the 250 piston has, and every other dimension is the same, bore size, compression height, wrist pin diameter and weight. I've also milled the head on a 250 engine .050" without having any piston/valve interference problems. With the flattop pistons and a milled head, the engine really comes alive. Jerry Hey Hotrod, all this modification stuff is off topic. And besides that you are polluting my mind with ideas of pursuing new avenues of adventure,for which I have neither the time nor the funds.  Carl
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Who, me- - - - -an enabler? Perish the thought!  Jerry
| | | | | Joined: Feb 2000 Posts: 5,225 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,225 | I was going to suggest the 307 pistons also, its a cheap way to increase the compression about 1 point. Just be sure the pistons you get a true flat top, not the generic replacements. Some have a chamfer around the top along with four valve reliefs. This one modification would do more for mpg then any other thing you can do.
Joe | | |
