4 members (Hotrod Lincoln, BC59, 2 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#1003272 01/31/2014 5:06 PM
The second and third leaf down on the front of my 51 are worn by the ends by the leaf under them. Maybe 20-30% of the way through. the top leaf and bushing areas are good. Is this a problem? Should I replace them? Thanks.
cassie #1003376 02/01/2014 1:08 AM
Is this a rub spot? Kinda makes the spring thinner. Or a short more like a cut point? Springs are hardened. I would think that the thinning would make it weak and a short wear spot would be dangerous. Might fail completely. I would look at replacing them. You might consider taking them apart and replacing the worn leafs. And you might consider a replacement set. Compare the costs in time and dollars to help decide. Do you have a "spring" shop nearby? Ask the 4x4 rock crawler folks they will know. That might get you on the road with not too much money and time. Let us know how you go and what you decided.
Steve H
cassie #1003506 02/01/2014 3:00 PM
That is kind of what I thought. There are no spring shops in my area so I will probably order new ones.
Thanks for your input.
cassie #1003522 02/01/2014 4:02 PM
For a cost-comparison, check out Classic Parts and Jim Carter.
Ask them about shipping costs.
Ask them if they use original-style leaf "clamps" rather than more modern looking bands/rubber (if that matters to you).
St. Louis Spring quoted me a price of $125 per spring. You may want to check them as well.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
cassie #1003815 02/02/2014 4:04 PM
Thanks to you all. St Louis Spring quoted $115 ea. I will order tomorrow.
