| | | Forums66 Topics128,026 Posts1,055,400 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | The second and third leaf down on the front of my 51 are worn by the ends by the leaf under them. Maybe 20-30% of the way through. the top leaf and bushing areas are good. Is this a problem? Should I replace them? Thanks. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Is this a rub spot? Kinda makes the spring thinner. Or a short more like a cut point? Springs are hardened. I would think that the thinning would make it weak and a short wear spot would be dangerous. Might fail completely. I would look at replacing them. You might consider taking them apart and replacing the worn leafs. And you might consider a replacement set. Compare the costs in time and dollars to help decide. Do you have a "spring" shop nearby? Ask the 4x4 rock crawler folks they will know. That might get you on the road with not too much money and time. Let us know how you go and what you decided.
Steve H
| | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | That is kind of what I thought. There are no spring shops in my area so I will probably order new ones. Thanks for your input. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For a cost-comparison, check out Classic Parts and Jim Carter. Ask them about shipping costs. Ask them if they use original-style leaf "clamps" rather than more modern looking bands/rubber (if that matters to you). | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | St. Louis Spring quoted me a price of $125 per spring. You may want to check them as well. Samantha | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Thanks to you all. St Louis Spring quoted $115 ea. I will order tomorrow. | | |
