1 members (walter74),
75
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 40 | Are school bus seats anything like the ones in the Subs for the same years?
Thanks, Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Do you have some pictures you can post of bus seats ? That would be a gold mine if they are the same.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'll bet they sit higher?
| | | | | Joined: Dec 2013 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 40 | Hello gentlemen, I'm going to find out in a day or two. Thanks for the input. Seems this hasn't come up in discussion before? Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | If you can,take some pictures and post them.
Thanks!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | it has been discussed before and if I remember correctly, they are definitely different. The frames have flange type mounts and the cushions are thinner and different radiuses. Pictures would help. | | | | | Joined: Dec 2013 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 40 | I'll get a look pretty soon. It's about an hour and a half from me. Its a '53 GMC school bus, so just hoping. There is one drawback, the owner took the seats out, and they have been outside for about 5 yrs., unfortunately. Anything special about this era GMC school bus? I think he has another one also, that was made into a camper bus at some point. I'm going to take a closer look at both of them.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Take pictures of each seat cushion and frame. Cheok the engine size, it may be the elusive 302. It will be stamped engine size first on the machined boss next to the distributer. It will start with eiter 248, 270 or 302. Check with the big bolt guys for additional input. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Most likely the bus was built by a coach builder who sourced the cowl and chassis from GMC and the seats from someone else. Even if they sourced the seats from the same supplier who built the Suburban seats I highly doubt they would be the same seats.
But I am interested in knowing what you find out. | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Here's the seats in my '59 bus, body by Carpenter. Probably different than what you will find. 59 school bus seats
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | School bus seats not the same . not even close. One side of bus seats bolt to the wall and the other side bolts to the floor. Prolly could be made to work but would not be stock looking. I had this thought while doing my sub until I looked at bus seats and realized it wouldn't look right.
Also there are lefts and rights to complicate things more
Weeds
| | | | | Joined: Dec 2013 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 40 | How many 302's and 270's should I buy if available at a low price. I already bout one 302 and one 270, and there's more. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | How many 302's and 270's should I buy if available at a low price. I already bout one 302 and one 270, and there's more. They are just like guitars. You always need one more. | | | | | Joined: Jun 2007 Posts: 20 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 20 | I have probably have cut up over 100 old school buses in the past for scrap. I never seen any seats that are close the original suburban seats. shape and contours are all together different, I have own chevy suburbans for many years and know when I see something that is close. But those seats can be made to fit, as it will be about close will be able to get without spending a lot of money,as those seats are made of metal ,and time can be spent to make something nice and close with out spending a fortunate. I a few weeks we will crushing out a old salvage yard here and in they got an 1956 GMC full size bus, I will be glad to remove a couple seats and set a side for someone who would like to try to make it work for their suburbans. | | | | | Joined: Dec 2013 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 40 | Thanks fellas, I finally got a look at the bus seats, and you're right, not even close. So, when I finally do acquire that project I'm looking for, I'm sure I'll be hunting up seats for it. There aren't many that I've come across that have all the seats, heck, lucky if they have the front ones. Bill | | |
