0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1001006 01/22/2014 2:42 AM
I'm tring to figure out what bezels I can use for my 1951 gmc since the originals aren't available anymore and they don't reman them either is there something I can use to give me the look of the originals I bought the lens and all the gaskets all I lack is the bezels
I used new lights for a newer Chev truck. They look very similar. I think they are TF parking lights.
1951 1 Ton Completed
There was a thread about similar bezels being used on some 1960's Chevrolet back-up lights a long while back. I apologize I don't remember exactly what years they were.
What year model did you use i wish I could find something that would work with the items I already purchased
Apparently the gm used the same bezels on corvettes from 53 -62 so I'm going to give that a try and see
Well that's a no go they are between 1/2 inch and 1 inch to small back to the drawing board
I'm almost ready to pull my hair out on this one I feel like I'm beating my head against a brick wall I keep striking out any suggestions would be appreciated
Don't know what size your lights are, you haven't
posted anything but these are 3 1/4". Might stick out
a bet further than the original lens but might look ok.
http://www.vintagetrailersupply.com/Beehive_Marker_Lights_p/vts-073.htm
Had a friend at one time with a similar problem, think
he finally found some used ones. Have you tried the
Swap Meet forum?
DG
Denny G
Sandwich, IL
I do belive the bezels need to be three inch cause 2 5/8 was about 1 inch to small
