7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami), 60 guests, and 2 robots.
Topics128,030
Posts1,055,421
Members48,422
#1003360 02/01/2014 12:12 AM
After looking at the kits and the cost. And because I am so tempted to do things my own way. Has any one ever tried to put a set of rotors on the stock hub? No fussing with tapered bearings that don't fit exactly. I know I would have to deal with the caliper support and dust covers. But I am not in love with the rotors as part of the hub. So, am I just crazy or..OK I am crazy. But it might be a nice project any way. Comments are welcome. Advice is too. I know you can get the drums off. And the rotors are held in place with the wheel studs. At least they were on my Jeep. Maybe some of the newer model parts would work with out too much trouble. The "offset" will have to be looked at as well as some kind of support bracket for the calipers but maybe some thing out there is workable? What do you think?
Steve H
Steve_H #1003362 02/01/2014 12:21 AM
There are some kits out there already that use late model rotors over top of the OEM hub.
The 99 and newer Silverados would be a good place to start.
Here's Chevs of the 40s kit, a little on the pricey side.
https://www.chevsofthe40s.com/detai...ke_Conversion_19471954_6_Lug_Rotors.html
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Steve_H #1003363 02/01/2014 12:23 AM
what truck?
Steve_H #1003370 02/01/2014 12:58 AM
Nice information Whitedog. Just what I was thinking. Now to get it warm enough to spend time in the wrecking yard with my tape measure. Might be fun.
Steve H
Steve_H #1003373 02/01/2014 12:59 AM
My bad..1952 1/2 ton.
Steve H
Steve_H #1003479 02/01/2014 6:12 AM
Interesting on the Chev's Of The 40's kit. Looks like it needs a spacer behind the rotor and an offset caliper bracket.
Steve_H #1004416 02/04/2014 4:48 PM
The Chevs of the 40's kit (looks like the same one at CPP) has the rotor behind the stock hub and the spacer attached on top. Rotor/Hub/Spacer. The studs are driven thru the rotor and into the hub. The spacer is attached with screws from the front which pass thru the three original drum rivet holes in the hub and into threaded holes in the rotor.
Steve_H #1004490 02/04/2014 8:49 PM
back yard wrench turner
Steve, I did the disc brake conversion on my '38. I have a '51 axle under the front.
I used the '51 hubs.
Machine the back side of the hubs where the rotor mounts.
The rotors are from '78/80 K10
the calipers are from 78/80 C10
Used longer wheel studs to go thru both the rotor and hub
I fabbed the brackets from 5/8 plate steel. I mocked it up with plywood to get the proper shape.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Steve_H #1004502 02/04/2014 9:15 PM
Wayne- got a picture of your brakes?
"The Fake Truck"
Steve_H #1004509 02/04/2014 9:55 PM
For what it's worth the part number for the longer studs is Dorman 610-179. The rotor and caliper info that Wayne67vert posted is consistent with what's used in the CPP kit.
Whitedog #1004547 02/05/2014 12:56 AM
driver side
passenger side
Wayne
1989 Silverado
Steve_H #1004686 02/05/2014 5:07 PM
Wayne: That looks like what I had in mind. Thanks for the parts list. Now I can go looking. smile
Steve H
Steve_H #1004690 02/05/2014 5:22 PM
Quick look at RockAuto gives approximate cost at about 150 for 2 rotors and 2 calipers. Add new brake lines, and hardware plus some metal, Maybe 300 all together...might work. Thanks!
Steve H
Steve_H #1004698 02/05/2014 6:02 PM
You will also need a master cylinder, residual pressure valves, flexible hoses and a distribution block.
my set up
Wayne
1989 Silverado
Steve_H #1004700 02/05/2014 6:10 PM
That is purty!
Steve H
