1 members (J Lucas),
85
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | After looking at the kits and the cost. And because I am so tempted to do things my own way. Has any one ever tried to put a set of rotors on the stock hub? No fussing with tapered bearings that don't fit exactly. I know I would have to deal with the caliper support and dust covers. But I am not in love with the rotors as part of the hub. So, am I just crazy or..OK I am crazy. But it might be a nice project any way. Comments are welcome. Advice is too. I know you can get the drums off. And the rotors are held in place with the wheel studs. At least they were on my Jeep. Maybe some of the newer model parts would work with out too much trouble. The "offset" will have to be looked at as well as some kind of support bracket for the calipers but maybe some thing out there is workable? What do you think?
Steve H
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Nice information Whitedog. Just what I was thinking. Now to get it warm enough to spend time in the wrecking yard with my tape measure. Might be fun.
Steve H
Steve H
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Interesting on the Chev's Of The 40's kit. Looks like it needs a spacer behind the rotor and an offset caliper bracket. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | The Chevs of the 40's kit (looks like the same one at CPP) has the rotor behind the stock hub and the spacer attached on top. Rotor/Hub/Spacer. The studs are driven thru the rotor and into the hub. The spacer is attached with screws from the front which pass thru the three original drum rivet holes in the hub and into threaded holes in the rotor. | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | Steve, I did the disc brake conversion on my '38. I have a '51 axle under the front. I used the '51 hubs. Machine the back side of the hubs where the rotor mounts. The rotors are from '78/80 K10 the calipers are from 78/80 C10 Used longer wheel studs to go thru both the rotor and hub
I fabbed the brackets from 5/8 plate steel. I mocked it up with plywood to get the proper shape.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Wayne- got a picture of your brakes? | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | For what it's worth the part number for the longer studs is Dorman 610-179. The rotor and caliper info that Wayne67vert posted is consistent with what's used in the CPP kit. | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | Wayne- got a picture of your brakes? driver side passenger side Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Wayne: That looks like what I had in mind. Thanks for the parts list. Now I can go looking.
Steve H
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Quick look at RockAuto gives approximate cost at about 150 for 2 rotors and 2 calipers. Add new brake lines, and hardware plus some metal, Maybe 300 all together...might work. Thanks!
Steve H
| | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | You will also need a master cylinder, residual pressure valves, flexible hoses and a distribution block. my set up
Steve H
