3 members (2-Ton, 78buckshot, Southerntruck), 141 guests, and 10 robots.
Topics128,078
Posts1,056,036
Members48,433
#100344 04/17/2007 6:29 AM
Junior Member
Junior Member
1 Offline
I just installed a 1958 235 engine in my 1954 chevy pickup. The engine turns over but does not start. I pulled the coil wire and did not see a spark when the engine cranks. Did I hook up the coil incorrectly? Does the + side go to the starter or the distributor? Do I need to change the condensor as the engine was 12V? It has the 1958 distributor still in the engine. All other parts were swapped from my old engine. All the components were working before I swapped engines. The old engine had a cracked block but did run. Thanks for any help.
#100345 04/17/2007 2:12 PM
welcome to the bolt...............looks like if the engine was running previous, it should be now..not sure why you would need to change the condensor if it was working before......this is a 12 volt truck, isn't it..........while I am thinking maybe someone else will chime in..
you might read this old post and see if it helps
click here
here is another one
click here
Redryder pix
My Hotrod
#100346 04/17/2007 2:22 PM
1954 Chevrolet Pickup,
Welcome to the Stovebolt. The + side of the coil should go to the keyswitch, not to the starter. This would apply if the rig was 6 volt and had a standard transmission. The other side of the coil which is - goes to the distributor. You will want a coil compatible with the trucks current voltage. The condenser should be fine. The first order of business would be to make sure you have voltage to the + side of the coil when you turn the key on. Do you have a voltmeter of some sort?
Stuart
#100347 04/17/2007 5:25 PM
Welcome aboard!
Quote
One of those probes with the light in it will work too.
#100348 04/17/2007 7:35 PM
Yeah, a test light is all you need. With the key in the "ON" position the + side of the coil should be "hot". That wire should come from a ballast resistor on the firewall and from there back to the ignition switch.
#100349 04/18/2007 4:31 AM
Junior Member
Junior Member
1 Offline
Quote
#100350 04/18/2007 4:37 AM
Junior Member
Junior Member
1 Offline
Thanks for all the advice. I rechecked the coil and made sure that it was connected correctly. I used a voltage meter and read 6 volts on the + side of the coil. I didn't have anyone around to crank the truck and check for a spark from the coil so need to do that next, I guess? Is there anything I should be checking on the distributor?
#100351 04/18/2007 5:04 AM
1954 Chevrolet Truck,
If you have good voltage to the positive side of the coil as you indicate, and the points are set properly, opening as they should, your plugs should fire. Re-check your point setting carefully. Make sure you have the wires in firing order sequence, 153624 and that the timing is proper.
Stuart
#100352 04/18/2007 6:11 AM
Junior Member
Junior Member
1 Offline
I will recheck those and try again. Thanks a million!
#100353 04/23/2007 6:51 AM
Junior Member
Junior Member
1 Offline
I got the truck running this weekend! I followed all the good advice and just need to finish putting the front end back together. Thanks for all your help.
