8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#722620 02/20/2011 4:05 AM
Looking for info on the cab utility tray
The part number may be RPO 987493. I am a sheet metal fabricator and would like to fab some of these. I could use dimensions and photos.
Larry
Camsore #722694 02/20/2011 2:35 PM
I'm unfarmilar with them, did they go under the seat?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
mounts on the back wall above the gas tank
squeeze #723236 02/22/2011 3:10 AM
??? Never heard of them, any one got a picture or scan of an illustration?
DG
Denny G
Sandwich, IL
I have the page but not sure how to attach
Camsore #724208 02/25/2011 4:20 AM
Camsore #724213 02/25/2011 4:38 AM
I don't have any information on a factory tray, but we did fabricate one of our own design for mine. Tray pic 1, tray pic 2, tray pic 3. The whole thing is mounted to the floor with 4 1/4-20 bolts. We sized it to be about 1" wider than the tank, with about 1" clearance above the line coming out of the top of the tank.
Bill Burmeister
That is a nice tray, is that aluminum?
Larry
Camsore #724224 02/25/2011 5:15 AM
Yes.
Bill Burmeister
Larry, what manual did you get that page from? The picture in Photobucket is much to small and to low of a resolution to make out any detail.
And Bill, what did you mount the tray to?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
try here Denny - save the picture alone and it comes out bigger wink
squeeze #724678 02/26/2011 4:55 PM
Yep, that'll do it William, thanks for the link. And it appears that ya go three screw heads pokin' out the back side of the truck after you mount the try in place. I'm not to nuts about that.
Since I don't know squat outside of the AD, I'm assuming that by 1957 the seat folded forward???
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I noted the screw head problem Denny, but I believe it could be attached without doing that .... yes, hinged seat backs from 55 onward .... instead of the tray, I added a plywood 'shelf' that sits on top the tank full width, does the job well
squeeze #724829 02/27/2011 2:33 AM
Denny, the side panels on my tray go all the way to the floor. It doesn't rest on the tank at all, and it isn't attached to the rear cab wall. I'll try to get some pics up showing how it's mounted.
Bill Burmeister
That sounds a little more friendly Bill. As you may recall I'm mostly into the AD's but I have seen a couple of examples of the mods so the seat folds forward on them, Pete52 for one. And Pete has a wood shelf behind his seat similar to the Squeezer. I'm always collecting ideas so I'll add these to my reference files. If I can ever get out from under these dang radios I'm buried in I might get back to actually working on the truck proper.
tks
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Did you ever get the specs and make some of the utility trays? I'd be interested in one.
1959 Chevy Apache Short Bed Step Side
1967 Cadillac DeVille Convertible
1967 Pontiac Firebird Convertible
This is not my day, the following links in posts above do not work (maybe because I am not a member): computerdeath
Bill - Webshots - I am not a member - I get a "Smile - Try Smile for Webshots for free)
Camsore - Photobucket - I am not a member, but the link is to a one-photo album - the photo is of the outside of a 59 truck - there are three albums - which album has tray photos?
squeeze - I do not have the Ark plugin
- the "try here" link is to an Ark browser plugin
- the plywood link is to a page that shows "404 Not Found"
computer_punch
Don't work for me either and I've been a member for a while...
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
sorry Tim, but lots of changes since 2011, the old Webshots doesn't exist any more, squeezes host dropped the mars.ark name, and Photobuckt rearranged things .... currently, the Opera community host is folding up, so my albums linked below will be gone by March, working on transfering them to Flicker .... always potholes and detours on this info highway wink
which just points out if folks see linked pics they want, copy them to your HD while you can
Amen, Bill
I know '50s Ferd's had these trays but I didn't think the Chev's got em.
red58 - good choice moving to Flickr. I've been a paid member there for many years.
Camsore,
Did you ever find the information on the cab utility tray?
Bob
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I do have an accessory manual with that schematic. At the beginning of this thread, Camore said he was looking for a utility tray. He explained he is a metal fabricator and wanted to make some trays.
I was wondering if he ever found one or get the specifications. I'd like to come by one for my truck.
Then back up our HD!
Copying that sort of stuff to a reference file has always been
a habit of mine even when the digital age was going thru
puberty. First camera was the DC40 then a few months later
a DC120. Still have some pictures stored on a floppy from
that. Those pictures probably look like the checker board
floor at Classic Parts compared to the hi-res stuff we're
used to today.
What's always been my downfall is not flossing, and---not
backing up my HD. So---I've got several old hard drives
sitting on the shelf in the basement with stuff like we are
taking about on them. Had a bunch of my photos on Webshots
when I first joined the 'bolt but they all got lost when it
folded. One of the bolters gave me a couple of old obsolete
Dell's last year and when the snow gets to be knee deep this
winter and my wood pile is used up heating the barn, I'm
gonna spend some time down in the man cave and try to
recover some of those old photos.
Some people never learn, me for one, I still haven't backed up
my new confuser and it's got a year and a half's worth of
work on it. Ya see, I can't get it to recognize that monster
external drive I bought for the old system, to many bits in
the new Dell for it to chew, or something like that. And I
ain't about to start storing anything of mine out there on a
cloud, they already own enough of me.
So, I've got all those pictures from this Utility Tray thread,
in a file, on a HD, somewhere in a box, on some shelf in the
dark corner of the basement.
Long winded aren't I! Just killin' time while I build up the
courage to go spend the next 12 hours in that cold, cold
barn. Burned up two pair of cotton gloves in the microwave
yesterday in an attempt to get some feeling in my fingers
so I could twist wire nuts out there.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Heres a wire nut twister for you Denny. Saves the fingers. LOL
https://www.platt.com/platt-electri...ers/Ideal/30-902/product.aspx?zpid=28549
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Nah, don't need any more gimmicks in the tool box, besides, I
taint twistin' all that many connections.
Never knew that accessory was offered by Chevy, but then again,
I'm never been able to move my interest in Chevy trucks past
early '55.
dg
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
