1 members (Dusty53), 174 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#1002882 01/30/2014 2:23 AM
Is the shifter housing (the one on the steering column above the steering box) lubricant just like axle grease or is there something special that goes in there? I popped the cap to look inside after I saw a bunch of old dried up crud underneath the housing. Inside looks pretty dry - a little hardened white lubricant stuck to the underside off the cap. Not having trouble shifting (except once in a while going into 3rd, goes - just have to double clutch once in a while), just got curious while cleaning crud from below. Did not see any spec in the manual for lubricant for this housing. Oh, 56 235, column w/OD Thanks, Dale
Riding in the Passing Lane
Put regular chassis or wheel brg. grease in it.
1972 Chevy c10 Cheyenne Super
Thanks George -- kinda what I thought, just wanted to be sure. Could not find it anywhere.
Dale
