2 members (BC59, Pre '68 Dave),
148
Mod | | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Is the shifter housing (the one on the steering column above the steering box) lubricant just like axle grease or is there something special that goes in there? I popped the cap to look inside after I saw a bunch of old dried up crud underneath the housing. Inside looks pretty dry - a little hardened white lubricant stuck to the underside off the cap. Not having trouble shifting (except once in a while going into 3rd, goes - just have to double clutch once in a while), just got curious while cleaning crud from below. Did not see any spec in the manual for lubricant for this housing. Oh, 56 235, column w/OD Thanks, Dale | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put regular chassis or wheel brg. grease in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Thanks George -- kinda what I thought, just wanted to be sure. Could not find it anywhere.
Dale | | |
