| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | Looking for info on the cab utility tray The part number may be RPO 987493. I am a sheet metal fabricator and would like to fab some of these. I could use dimensions and photos. Thanks Larry | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I'm unfarmilar with them, did they go under the seat?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | mounts on the back wall above the gas tank
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | ??? Never heard of them, any one got a picture or scan of an illustration?
DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | I have the page but not sure how to attach | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't have any information on a factory tray, but we did fabricate one of our own design for mine. Tray pic 1, tray pic 2, tray pic 3. The whole thing is mounted to the floor with 4 1/4-20 bolts. We sized it to be about 1" wider than the tank, with about 1" clearance above the line coming out of the top of the tank.
Bill Burmeister | | | | | Joined: Feb 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 59 | That is a nice tray, is that aluminum? Larry | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Larry, what manual did you get that page from? The picture in Photobucket is much to small and to low of a resolution to make out any detail.
And Bill, what did you mount the tray to?
Denny Graham Sandwich, IL
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | try here Denny - save the picture alone and it comes out bigger  Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, that'll do it William, thanks for the link. And it appears that ya go three screw heads pokin' out the back side of the truck after you mount the try in place. I'm not to nuts about that. Since I don't know squat outside of the AD, I'm assuming that by 1957 the seat folded forward??? Denny Graham Sandwich, IL
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I noted the screw head problem Denny, but I believe it could be attached without doing that .... yes, hinged seat backs from 55 onward .... instead of the tray, I added a plywood 'shelf' that sits on top the tank full width, does the job well Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Denny, the side panels on my tray go all the way to the floor. It doesn't rest on the tank at all, and it isn't attached to the rear cab wall. I'll try to get some pics up showing how it's mounted.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That sounds a little more friendly Bill. As you may recall I'm mostly into the AD's but I have seen a couple of examples of the mods so the seat folds forward on them, Pete52 for one. And Pete has a wood shelf behind his seat similar to the Squeezer. I'm always collecting ideas so I'll add these to my reference files. If I can ever get out from under these dang radios I'm buried in I might get back to actually working on the truck proper. tks Denny Graham Sandwich, IL
| | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Did you ever get the specs and make some of the utility trays? I'd be interested in one.
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This is not my day, the following links in posts above do not work (maybe because I am not a member): Bill - Webshots - I am not a member - I get a "Smile - Try Smile for Webshots for free) Camsore - Photobucket - I am not a member, but the link is to a one-photo album - the photo is of the outside of a 59 truck - there are three albums - which album has tray photos? squeeze - I do not have the Ark plugin - the "try here" link is to an Ark browser plugin - the plywood link is to a page that shows "404 Not Found" | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Don't work for me either and I've been a member for a while... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sorry Tim, but lots of changes since 2011, the old Webshots doesn't exist any more, squeezes host dropped the mars.ark name, and Photobuckt rearranged things .... currently, the Opera community host is folding up, so my albums linked below will be gone by March, working on transfering them to Flicker .... always potholes and detours on this info highway  which just points out if folks see linked pics they want, copy them to your HD while you can Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I know '50s Ferd's had these trays but I didn't think the Chev's got em.
red58 - good choice moving to Flickr. I've been a paid member there for many years. | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Camsore,
Did you ever find the information on the cab utility tray?
Bob
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | I do have an accessory manual with that schematic. At the beginning of this thread, Camore said he was looking for a utility tray. He explained he is a metal fabricator and wanted to make some trays.
I was wondering if he ever found one or get the specifications. I'd like to come by one for my truck.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Then back up our HD! Copying that sort of stuff to a reference file has always been a habit of mine even when the digital age was going thru puberty. First camera was the DC40 then a few months later a DC120. Still have some pictures stored on a floppy from that. Those pictures probably look like the checker board floor at Classic Parts compared to the hi-res stuff we're used to today. What's always been my downfall is not flossing, and---not backing up my HD. So---I've got several old hard drives sitting on the shelf in the basement with stuff like we are taking about on them. Had a bunch of my photos on Webshots when I first joined the 'bolt but they all got lost when it folded. One of the bolters gave me a couple of old obsolete Dell's last year and when the snow gets to be knee deep this winter and my wood pile is used up heating the barn, I'm gonna spend some time down in the man cave and try to recover some of those old photos. Some people never learn, me for one, I still haven't backed up my new confuser and it's got a year and a half's worth of work on it. Ya see, I can't get it to recognize that monster external drive I bought for the old system, to many bits in the new Dell for it to chew, or something like that. And I ain't about to start storing anything of mine out there on a cloud, they already own enough of me.
So, I've got all those pictures from this Utility Tray thread, in a file, on a HD, somewhere in a box, on some shelf in the dark corner of the basement.
Long winded aren't I! Just killin' time while I build up the courage to go spend the next 12 hours in that cold, cold barn. Burned up two pair of cotton gloves in the microwave yesterday in an attempt to get some feeling in my fingers so I could twist wire nuts out there. Denny Graham Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nah, don't need any more gimmicks in the tool box, besides, I taint twistin' all that many connections. Never knew that accessory was offered by Chevy, but then again, I'm never been able to move my interest in Chevy trucks past early '55. dg
