5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#1002618 01/28/2014 10:50 PM
This the the nut used on the repo hood front emblem
...pic...
has a build in Flange washer
My local hardware store didn't have anything like it
anyone know what they are called?
thanks
DADS50 #1002619 01/28/2014 11:01 PM
Don't know the name either, but I've gotten them from restoration specialties in PA, they have quite the selection of trim accy's, and an online catalog..
those are sheet metal flange nuts, should be able to find some at NAPA or other FLAPS, probably on the 'Help' rack
The restoration referenced above calls it a flanged pal nut
Ill try the flaps now that I know what to ask for
I hope I don't have to buy 100 of them
I think I need size 12-24
The hardware store I use usually has a good selection of odd fasteners but didn't have that one.
Ex Hall Monitor
Ex Hall Monitor
In another life when I was a body man we called the speed nuts.
Sir Searchalot
Sir Searchalot
That is also known as a tinnerman. There are variations of tinnermans, Most common are the flat Speed nuts and the clip/J or U Speed nuts. If you don't find them where Bill has stated; McMaster Carr has them under "Spring Speed Nuts/Flange Speed Nut. $7/100!!
Sir Searchalot
Sir Searchalot
Small quantity: Dorman 45571, Summit and others. (4 for $2) They call them thread cutting nuts, may or may not work. Dorman has many sizes. This is 3/16 (.187), closest I could find to 12 (.216).
Autozone has Dorman assortment 961-330.
thanks for the tips
I have one more hardware store I can try before I spend 6 dollars shipping for the 4 nuts
its called Mcfadden-Dale I think they are only west coast.
Sir Searchalot
Sir Searchalot
You know Home Depot and many others have the flat speed nuts that can be used on sheet metal or machine screws. Those will work just as well, albeit not "original". Maybe I'm just a hacker but I use regular hex nuts/nylon locking on emblems if they have a good thread. Some emblems need a push nut.
that type nut works best for the area of he emblem
...pic...
Sir Searchalot
Sir Searchalot
Isn't using a flat washer with a Nylon Lock Nut the same profile? Fits the same? I'm not seeing a problem in the pic. If you are trying to be original, I understand.
The studs are also threaded into the emblem
Just helps with removal and install to have that type of nut
A lock nut could drive the stud into the emblem face and possibly dimple it
More for convenience
Sir Searchalot
Sir Searchalot
Yes, that's a real good point.
You can always depend on McMaster Carr Gus. And you can keep it accurate by using the proper hardware.
http://www.mcmaster.com/#spring-speed-nuts/=qgm6te
Denny G
Denny G
Sandwich, IL
Just to clean up this thread
I went to my local carquest and asked for the above nuts
Of course they refer to them as something totally different, and at first didn't know what I was talking about
But the did have them on the rack.
4 bucks
...They call them washer lock nuts at carquest...
...another pic. SKU number...
Nice not to have to pay shipping.
Now, on to trying to save the original emblem on my Dads old truck.
Thanks for the responses...guess I should of just checked the flaps in the first place (good call Bill) At least the info is out there now for the next guy
Sir Searchalot
Sir Searchalot
thanks for the follow up. I saved those pics of the bag.
