2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 16 New Guy | | New Guy Joined: Dec 2008 Posts: 16 | I am looking to rebuild my trico vacuum wiper motor for my 36 GMC. Been surchasing the internet for a rebuild kit and have not found one for it. I have found a lot for early Ford model A. Pictures of the kit look like they will work. Does anyone know if they will before I buy something I can not use? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | No rebuild kits are available. You can send it to Ficken Wiper Service and he will do it for you at a reasonable price. www.wiperman.com | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | As info here is Ficken's web site. http://www.wiperman.com/I rebuilt mine. Be careful with the disassembly. take photos, clean all parts well (pay attention to ports and tubes be sure they are clear/open), cut new gaskets as needed and reassemble. Good luck, Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | As info here is Ficken's web site. http://www.wiperman.com/I rebuilt mine. Be careful with the disassembly. take photos, clean all parts well (pay attention to ports and tubes be sure they are clear/open), cut new gaskets as needed and reassemble. Good luck, Harold What gasket material did you use to rebuild yours? -W | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | W, I Used Fel-Pro Rubber -Fiber Sheet, P/N 3157. It is 26" x 10" x 1/32". It is available at most auto parts stores. Mine came from Auto Zone. Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 36 | | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | You're still in moderation, so he can't PM you. This is your 2nd post. After you've had 4 approved, you'll come out of moderation. | | |
