| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | I am in the process of a frame off restoration of my 1965 C10. I plan on using 2 1/2" drop spindles on the front and 3" drop coil springs on the rear. From everything I have read the original tracking arm will still function properly as long as the drop coil springs do not exceed a 4" drop. Can anyone confirm this is correct? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Just a note that I would be careful with which drop springs you get. A lot of drop springs use smaller diameter steel and have much less load carrying capacity. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory trailing arms, are still fully functional with 3" drop springs in the rear. I believe you must use lowering shocks, in conjunction with 2-1/2" front drop coils & 3" drop coils in the rear. Verify this with the drop coil spring provider. Good luck with your '65 Chevy truck project.
